1 - 7 of 7 Posts
It twists, turn it, slip the mat over and then turn it back 90 degrees.
Knew that, but it seems that the open mode is 90 degrees off and the locked mode is 90 degrees off, look closely at the pictures again.
I bought mine from carmatsuk and the front mat 'holes' come in that orientation too. It was quite easy to prise off the plastic receptacles and rotate them 90 degrees. I had to leave the bottom parts off though because there wasn't enough room to rotate the lugs with them on. Other than that, the front mats fit really well.
On a side note, the rear mats that came with them don't fit very well. I bought the ZS Auto version (no option for EV specific) assuming they would work - sadly not.
1 - 7 of 7 Posts
