1 - 2 of 2 Posts
Hi
As it looks like the passat is basically going to be parked up for at leat the next twelve weeks as I am working from home are there any tips on how to best look after the battery?
Dave
Dave
Check out this thread. If you don't have the opportunity to run the battery down by using it I'd advise running the heating instead. Be aware that you may need to keep an eye on the state of the 12v battery as I'm not sure how good the system to charge it up from the HV battery is on your hybrid. Also follow the advice to pump the tyres right up to something like 45-50 psi (read the limit on the side walls) to avoid them flat spotting if you are literally not going to use the car at all.
1 - 2 of 2 Posts
