i understand to get the car back to normal will take 50-100 hours of equalisation charging per10V out. 445-455V.
If your car is out by 20V, that will take at a guess 100-200 hours of equalisation charging to get back to 455V.
The BMS i understand can only move around 1-2mV per cell per hour.
So, my takeaway is it’s going to take a while to sort out.
I understand that MG tested this by leaving it in ‘Ready’ overnight, then charged during the day and repeated a few times. Not many of us can do that though.... if we want the car to be there in the morning!!!
Hi Mike - Thanks for that information.
Bloody hell ! - Then under the current ( C19 ) restrictions and low usage patterns by many owners, that is going to take MONTHS to return to any type of normal / expected range usage then !!!!!!.
What is your personal feelings on that subject then Mike, I know you are still covering a lot more mileage than most of us right now and therefore your reduced range is likely to have a much bigger impact on your work.
What happened to the statement :-
"Four to six charge's is what is expected to re-balance the packs back to normal".
Yes - If you intend to follow MG's lead and leave your car powered up all night to drain the HV pack, and then carry out an almost daily, recharge of your HV battery again a few times a week, then this maybe possible.
I guess, here is the million dollar question :-
Have MG actually proved 110% that by carrying out this repeated process, after the BMS upgrade, that this does actually return the car to it's normal expected range / charging / pack voltage ?.
Our is this just ANOTHER rushed through BMS software upgrade like the last two that is likely to be subjected to another update again in the future and is just buying more time for the correct fix that we are long over due ?.
The latest BMS update released on the 19th Jan 2021 is welcomed of course.
But clearly NOT a "Quick Fix" by a HUGE mile !.
Even after the update has been applied, the process to return the car to the normal expected condition, is far short of a practical solution for many many owners.
Given that the learning curve to now balance the pack is going to be cycle lengthy process, then I am sure NOT many owners are going to be ecstatic about this news.
Some owners who have had the "Buggy" software installed in their cars for a long time now, are only reporting 430 - 435 volts on the HV pack after a very over lengthy charge / balancing process.
Even after the so called "Fix" they still going to have to subject their cars to a continued process of lengthy charges / balances, before their HV battery voltage is returned to the magic 445 volts.
A few members ( like myself ) who have had now had the update already, are witnessing a pack voltage of 450 volts after a full charge / balancing process on first boot up of the car, and a reported GOM predicted mileage of around 162 miles.
There is a bit of a similar pattern forming here, either correctly or incorrectly as
nobody appears to be able to verify this ?.
Given we are now seeing 450 volts, then we are only slightly behind the magic expected figure of 445 volts.
So in theory our HV pack voltage SHOULD recover quicker than most, but let's see.
Owners who have had their HV packs badly affected by previous "Buggy" software issues, could therefore be this sitting on a pack with only 430 volts and also have a small usage case due to C19.
For them, they face a long "slog" to get their HV packs back up to correct operating values and restored range capability.
I don't rightfully know who's fault this mess truly is ......... but one thing I am confident of here, it is NOT owner's fault !.
This subject is likely to drag on for some time folks.
And so it should until it is finally resolved.
MG should put out a statement to the affected owners, but that is clearly not going to happen !.
