1 - 20 of 37 Posts
I have just bought a used Nissan Leaf (2013 model). It came with a 13 amp charger for home use, which is easy, but no other cable.
Thinking I might need to charge at a public chargepoint, I bought a Type 2 to Type 1 cable for £125. The Type 1 end fits the car, but I just tried to charge at a Pod Point, which is Type 2 according to Zapmap, and found that I had two female ends! The Type 2 end of my cable is a female connection and so is the outlet on the Pod Point.
I drove to another Pod Point and found the same thing. Is my cable useless, or are there other networks where the Type 2 connection is male on the charger side?
By the way, what do Pod Point mean by "open charge"? Is it free?
I haven't tried Pod Point but i purchased Type 2 to type 1 cable and used that with Polar charger without issue.
Have a look at Pod Point app. It will tell you about associated charges if any
Sent from my SM-G960F using Tapatalk
It sounds like the cable you have is intended to be used as an extender plugged into a Type 2 tethered cable, when what you need is a type 2 to type 1 public charging cable. If you can’t change it, I think you may be able to get an adapter which would give you both options.
What you’ve bought there is an extension cable. You would need a chargepoint with a tether (type 2) which are very rare except at peoples houses possibly.
99% of charge posts in this country have a type 2 socket so you’ll need a type 2 to type 1 “Public charging cable”.
Discussion Starter #8
Thanks, Rick and all who replied. The cable was sold by PowerPac as a charging cable for Nissan Leaf, so I guess they have sent the wrong thing.
I'm puzzled by what you actually received. Could you show some photos of the Type 2 end?
Discussion Starter #15
All I can say is that this connector does not go into a Podpoint Type 2 charger. At two separate locations.
I'll wait and see what the supplier says.
It is a mystery because that looks OK to me.
Are these pod points not correctly initialised and are putting up a block that prevents you pushing the lead in? What does the socket on them look like and what happens when you actually put the lead into it?
That looks like a Type 2 male that will fit in the socket found on the PodPoint public charger.
A lot of ChargePods are free to use, most will give you 15mins just by pugging in, others may need the PodPoint App to claim a charge so it charges longer.
Check out something like ZapMap or PlugShare to find where the chargers are.
No. PodPoint operation starts with inserting the charge cable into the post and the car. Then confirm your session on the app without which charging will stop after 15 mins.
Unless someone has vandalised them there should be nothing impeding plug insertion.
Discussion Starter #20
The Podpoint socket looks exactly like the socket on my cable. The pins are recessed, so there is no way of pushing them in to anything. It's a physical problem, not anything to do with the electronics.
These Podpoints were both in Exeter.
1 - 20 of 37 Posts
