1 - 6 of 6 Posts
Following up on my question of a few months ago.
Looking for 22kW charging in Salford area. Is there any there yet? Plenty of 7kW I know via CYC but 22kW would be extremely helpful! Any advice much appreciated!
Hi Mark all the GMEV rapid chargers are now installed, locations as per this map.
Sadly the Tennis Centre charger is dead, the one at MMU has a dodgy button, and the one on Stott Lane isn't showing on any maps yet, however it was working a few weeks ago and I think @CYC have said it is available to use. The Tennis Centre is only one that is not 24 hours, and all three permit a 1 hour max stay.
Hope that helps! What are you charging at 22kWs?
The MMU charger can be started from a mobile device and then you can get the charge to start if you give it a "convincing" press (the palm of your hand usually works).
I've still never managed to find the Tennis Charger, the Salford charge point in opposite the Hope Hospital in their car park and there are around 6 7kW charge units there.
1 - 6 of 6 Posts
