Anyone managed to get the dedicated app to download the latest map?
There is a notification in the MyVauxhall app that says there is a new update and to download the app to your PC/Mac. Once the app is downloaded you enter your VIN and select the vehicle. You then either accept the default download location or choose a different one. You then start the download which should take some time depending on your broadband speed as the file is humongous.
Unfortunately, each time I start the download it stops immediately with the message:
I checked the information in Terminal and it appears that there is a security certificate mismatch going on behind the scenes. Typical crappy PSA group software engineering and quality control. I have tried using both the Vauxhall and almost identical Opel downloader with the same result.
Does anyone have the direct URL for downloading the update? They have dumbed down the app to download the software and then format your USB stick and then load it on to the USB stick. Nothing that can't be dome manually as was previously.
Anyone managed to actually use the app to perform the latest map update?
