1 - 5 of 5 Posts
Hi,
I recently had a home charger installation. I have to EO mini pro which has the juicenet app.
I've set the car to have max 80% when charging over AC.
When setting up the charge last night I used the juicenet app dial and set to 80 also.
The app pinged me to to tell me when it had finished. Cool
But then the car pinged me to says the charge was 70%
What did I do wrong with the juicenet app? Shouldn't it know what charge the car has/needs?
Kia Soul EV 2020
Hi,
Check the setting in the car. I'm not sure which will take precedence, but if your car is set to charge to 70%, your charger will have no other control over this.
Or maybe you have timer setup?
This Max guy seems to get around. He's confused a lot of people on the forum.
The car setting is definitely 80%
The EO app has a dial like this
135954
So when it's plugged in you can set both the start and finish amounts. I don't understand the start, as this doesn't seem to pick it up from the car
Maybe I should just have this as 0-100 and let the car handle it?
I let the car control it; I have my EO set to 0-100
I do however use the EO timer as that is easier to adjust than the car.
Sent from my Pixel 4 using Tapatalk
1 - 5 of 5 Posts
