1 - 20 of 235 Posts
i3 120Ah->Kona 64kWh->e208->ID.3 Family->Model 3 60kWh LFP
ETA - this is for cars with the widescreen
For older cars, this link is what you’d need I think.
Discussion Starter · #2 · (Edited)
Overview of the changes here:
ETA - not sure, as haven’t had much chance to play around with the new version yet, but some of the sat nav tweaks only apply in the US for now I think.
Also...
Current radio station etc now shows on Home Screen.
CarPlay and AA can be split screen.
You might want to edit the title as it says April 2012 not April 2021!
Oh if only there was a USB update to take us back to 2012...!
Had a bit more of a play now and there are quite a few little improvements which add up.
Home Screen map is more visible, shows radio, can tap to go radio, weather or nav (maybe you could before - can’t remember).
A good one for some is that you can get some cloud calendars to show on the split screen.
The icons have changed again, not really worse or better - just a bit different again.
Discussion Starter · #10 ·
The USB stick should only contain the following files (you might need to remove them from the containing folder), and I’m not sure about exFAT - most people seem to be using FAT32.
143467
1 - 20 of 235 Posts
