1 - 11 of 11 Posts
Hello all. I have a Mercedes E300DE saloon, with a battery range of 22 miles. This is not anywhere near the figure that has been officially announced, nor is it anywhere near Mercedes official WLTP figures... I thought the idea of WLTP figures was to prevent the massive exaggeration factor seemingly displayed by most (ALL) motor manufacturers. I've taken this issue to Mercedes and they suggest that 22 miles is doing really well.The dealership said that my driving style is the reason for the lack of range (even though previously they had said I was doing well at 22 miles full to empty battery, hmmm something fishy going on here me thinks,might be so bold as to suggest they are telling lies in order to make me go away, which I wont) so i suggest I might be clutching at straws but is there anyone else here who has an E300DE who would be prepared to tell me what electric only range they are getting.
It has blunted what has otherwise been a good experience (apart from the car rattling which can't be fixed apparently) but not sure if I would ever be a repeat Mercedes customer..
If you are using the battery for warming the car up then there you go.
WLTP does not include car heating 'cost'.
You will lose 2kWh heating the car up and then another one or two keeping it warm.
How many kWh do you have?
How many miles do you need to go?
Donald, thank you for the reply. I do not use the electric warm up feature UNLESS its still plugged into its wall box..... the battery capacity is listed as 17.5 Kw. I use the car for work and back. My bone of contention is that it SHOULD DO more than 30 miles electric only range and it doesnt..... BUT Mercedes and most of the press reports on the car say 31-42 miles range.Not to mention the bloody abysmal fuel economy which I mentioned in my other post.
13.5kWh and 34 mile range according to this press release:
The e-brochure says 13.5kWh and an all electric range of 29.8 to 27.9 miles WLTP. There is a disclaimer that they achieve this battery range using a combination of battery and fuel. In test conditions, It will go that far on the battery but only if you also use the diesel.
That's about 2.2 miles per kWh which is pretty terrible but not too surprising for a big heavy PHEV. The kerb weight is 2,140kg. For comparison an Outlander PHEV is 1,880kg. A BMW i3 is around 1,300kg.
With any EV winter range is going to be lower end of the range. You might get close to 30 miles on warm dry days.
Isn't this car just a bodge to get the low BIK rate? It's never going to get the range they claim, they don't really care. BMW do the same at the moment too.
I had a test one for a couple of days, I nearly made it fully into work (28 miles mainly country a/b roads) on full electric. The diesel fired up a couple of times, but only for a few seconds. I'm usually a fairly economical driver.... Tips to maximise battery range is to be gentle with the throttle, lift off as early as you can, and watch what the heating / air cond is doing.
I have recently bought a 300De and have pretty much exactly the same experience as you Mark ,about 20 miles to a charge max, hills drain the battery and I live in a hilly London suburb so all in all, disappointing .
Isn't it a bit bonkers that the Volt/Ampera is so efficient with its engine motor arrangement and just 10kWh? Designed and built in the 2000's, you'd have expected some improvements by now? PHEVs seem to have gone backwards. I think part of the problem is that the 1st tier suppliers are still trying to flog their old technologies, ancient gearboxes with mutiple shifting gears, they want to eek those out to the last day possible by simply throwing an electric motor in there, somewhere. Whereas Voltec was a completely different/new concept.
AutoExpress magazine has a report item on "their" E300de saloon.
Funnily enough, 20 miles real ...
Mind you their attention to detail & EV awareness level as a "professional" magazine is shown by the photo of a Chad plug --- good luck trying to plug that in.
Jeeeeze.
I agree with Mark I thought the move to WLTP was to quote a real world figure.
I was hoping the Merc 13.5kWh models would touch the 30mile mark in reasonable driving.
Maybe the WLTP needs to be reworded as " Max under lab conditions, intended for comparison purposes only"
The estate version of this car seemed like the ideal car for me at first. Most of our journeys are short ones and we have solar PV roof panels so daytime charging is potentially free.
I like diesels and the current Mercedes 220d engine is so smooth and quiet as well as having very low emissions.
But for journeys above 20 miles the hybrid version doesn't make much sense. The increased fuel consumption, reduced load capacity and additional cost make the standard 220d SE
the more sensible choice, sadly.
At the moment I'm getting about 2.6 - 2.7 mpkWH which is around London and without pre heating, although the car doesn't live outside (underground garage). For me the car 'works'. I can do most localish trips on electricity only, but when we do longs trips (remember those days...) it's still good enough on diesel.
But also, it's a nice place to be. Really hides its weight well and doesn't resort to stiff suspension to do it. I'd prefer a better audio system, but as all those options were deleted....oh well.
1 - 11 of 11 Posts
