1 - 2 of 2 Posts
I've had my PHEV for a couple of months. Only this week the council have finally converted a lamppost outside my house to a charging point using ubitricity charging solutions - Easy and convenient charging for everyone
I'm having problems with getting the car to charge and can't find a solution.
I connect and the charging commences - yellow flashing light at the charge point.
When I return to the vehicle it has only taken on 0.3 or 0.6 KWh or so - and the charge point light is flashing red [fault in charging process].
Any ideas?
Many thanks in advance
Louise
If the car charges normally elsewhere then it's the new installation that's at fault. Either the post socket or the Ubitricity 'brick' used to arrange payment. It could be an issue over the car detecting an adequate earth, or a faulty lead/brick unit. Ask Ubitricity to get back to sort it out for you - preferably meeting their engineer on site to demonstrate the issue and check after a fix.
1 - 2 of 2 Posts
