I've installed several Viridian charge points in exposed locations. Super quality diecast aluminium enclosure with good deals.I have read that Viridian charge points are supposed to be built for durability and the tethered version is rated IP66, has anyone got opinions/experience of these?
Actually the IP rating only applies to dust and water for a new unit. You want something mechanical robust as well. Not flimsy Rolec plasticity like.Zappi, for example, is IP65 rated. As I'm sure you know, the second digit being a 5 means it is protected against low-pressure jets (6.3 mm) of directed water from any angle (limited ingress permitted with no harmful effects). That should cope with most weather conditions.
The second digit being a 6 would be for protection against powerful jets (12.5 mm nozzle) of directed water from any direction. That is, the likes of a pressure washer. I don't think even Cornwall equates to that.
Not often a problem in west Cornwall I suspectEven then, additional weather protection to stop freezing rain might be a good idea.
Yes, too true. Freezing rain inland Highland Scotland can freeze a socketed cable into the charger. No fault of the Viridian EVSE which I think use Phoenix Contacts sockets.Not often a problem in west Cornwall I suspect![]()
Sure felt like it last time I was on holiday in a tent thereI don't think even Cornwall equates to that.
You're just a wimpSure felt like it last time I was on holiday in a tent there
