1 - 20 of 43 Posts
Hi All,
As some of you are aware I have started documenting my ZS EV ownership on YouTube. I’ve never done anything like this before so I am learning!
rather than keep posting separate videos in different threads I’m going to keep them all in one thread, just like I did with my
Black Tekna, no longer ‘The Lemon’ thread
Discussion Starter #2
Reactions: avhation
Reactions: avhation
Reactions: Paolo and Carty
Discussion Starter #9
Mike, does this mod invalidate the warranty ?
On which bit?
MG would struggle to say that they wouldn’t replace the battery because the suspension dampers had been changed. I can always put the original ones back on....
Reactions: Carty
I remember doing something similar when I rebuilt my MGB GT ages ago...I rallied that car afterwards, as well as using it for my daily commute (50 miles each way).....certainly worth considering.....
wouldnt slightly wider tyres help as well?
On which bit?
Well, it’s not very likely that you will require a warranty claim on the shocks, now they are sitting on a self in the garage Mike !.
Bilstein have been making quality suspension parts for more years than I can remember.
One member in the VW forum personally fitted rear shocks to his car to cure a rattle.
This was after VW had fitted two different sets of OEM units to his car under warranty.
On both occasions the rattle returned after less than 200 miles, if I remember correctly.
He did over 1,000 miles on the Bilsteins and reported no further noise from the rear end of the car.
The Bilsteins will be streets ahead of the MG OEM shocks you can be sure.
As they are regarded as a upgraded sport units, they will make the ride a little firmer ( Mike has already said this ) but the over haul handling of the car will be majorly improved.
I think a pair of rears for the GTI was around £85 ish ?.
This is less fitting of course.
Discussion Starter #14
It would certainly need you to inform your Insurance company.
I have... long story short they wouldn’t cover the modification. Changed insurer and paying the same elsewhere who accepted the mods.
Discussion Starter #15
The Ohme app & the MG....
Discussion Starter #16
Discussion Starter #17
A real world range video in 3-9°C dry weather & further thoughts.
Reactions: Carty and dparr59
MG EZS 2020
Nice video Mike. I've put in a request for you to show us how to get some of the info you refer to. Things like m/kWh and such. I'm having a real struggle to work out how to get such things that were an absolute doddle on Zoe.
Miles per kWh is easy - it pops up on the LCD in the centre of the dash, use the menu arrows on the left side of the steering wheel to find it. You have one for your current trip, and another which you can reset manually.
Great video Mike !.
At only 2 mins into your video, my ears locked into the "Creaky Dash Board" noise when you where travelling across any uneven ground.
It was more evident when you where travelling slowly over that hardcore covered car park.
I kept waiting and waiting for you to make a comment about it.
Sure enough, you where right on top of the issue in your presentation.
Mine ( like many many others I suspect ) has the same problem.
I started within about 2 - 3 weeks of having the car.
The creaking can be heard from BOTH sides of the dash board ( but at different times ) giving the impression it is emulating from the inside of the car.
But thanks to brilliant detective work by @Flyingstoo .
He has already tracked down the culprit of this problem.
If you are in anyway remotely interested, in knowing what causes this issue, then read on.
Right, if you stand directly where the drivers door meets the O/S/F wing panel.
O.B.T.W. - This test works on either side just for the record.
Now, focus your gaze both slightly down and then towards the area where the front wiper are sitting against the wind screen, got it !.
Right, there is a metal body coloured panel ( white in your case Mike ) that has a row of slots, running in a front to back direction.
This body coloured panel, is the air intake for the heater ( hence the slots ) and it usually provides access to the wiper motor and it's mechanism as well as a rule.
You can see that this panel runs right across the width of the car and at the point closest to the glass, you will see that this panel has a black rubber gasket fitted to it.
Now, if you push down hard with your fingers on this rubber gasket and listen carefully.
Bingo - you should be able to reproduce that very same tight creaking noise that you can hear inside of the car, it does it on my car 100% for sure !.
And you are only able to apply force in a very small area with the pressure of your fingers.
Remember this long gasket is in constant contact with the entire bottom edge of the glass wind screen, so at any point of movement or deflection you are going to get that creaking noise.
I think this is why it is easy to be fooled into believe the noise is coming from INSIDE of the car !.
@Flyingstoo has been able to remove the fastener's that secure this panel and carefully apply a film of silicone grease to the seal and replace the panel.
He reported an instant fix to the problem, a fantastic proof of concept to a problem most owners will either have already or may encounter at some time in the life of their ownership, I have little doubt about this.
This info provided by @Flyingstoo is really really useful.
If you intend to ask your dealer to investigate this annoying problem, I suggest you make them aware of these facts.
Nothing worse than having the car at the dealership all day, then to be told :-
"Sorry Sir, we was able to locate / replicate your complaint on this occasion, you will have to bring it back for further investigations" - or in other words, they haven't touched it !.
Even worse, they misdiagnose where the noise is coming from and then proceed to pull apart some of interior trim ( that never get refitted properly ) in an attempt to fix the problem, which it does not of course.
Now you have rattles in places you never had before, because the interior trim clips have been broken in the disassemble process.
As a long retired tech, I absolutely HATE taking my car into the dealer.
I fully intend to rectify the issue myself if at all possible.
We are not making a 120 mile ish round trip and waste a day hanging around, to be told they could not find the fault !.
I understand how the system works ( or not ) in these maters.
Sorry members, long rant now over - phew !.
1 - 20 of 43 Posts
