After 6 months of charging our 24kWh Nissan Leaf nearly every night using a genuine Nissan EVSE 3 pin plug 13A charging brick, via a 13A rated extension lead, we suddenly had a near disaster. My wife's keen sense of smell saved us from a serious fire: at 11pm, when we were about to retire to bed, she said she could smell a slight smell of electrical burning. The smell was in the kitchen area of our open plan house, and my wife's nose led her to the corner where the extension lead was plugged in, behind the microwave:
As you can see, the live pin overheated, melting the plug around it. I had to pull the pin out of the wall socket with pliers. The house is less than two years old, there is an MCB on the ring main circuit. The car had been charging for about 45 minutes and was at about 60% when I plugged it in. The extension lead is otherwise fine, I have fitted a heavy duty MK brand plug on it after cutting a few cms off the lead and this plug is only getting vaguely warm. I checked inside the old plug and the live wire was still firmly attached to the plug terminal, the plug was inserted fully and the cable was not under any strain. I have now also installed a surge protector adapter, which has a thermal cutout, between the wall socket and plug.
