If you are fairly confident about the range being enough for the foreseeable future, I wouldn't worry too much. The used values are pretty good now and you probably won't be taking much of a hit if you do need to sell it on in future. Living in the city without home charging isn't impossible either, so you could still give it a try and see if you could make it work should that happen.
MOT History does have a few fails. but it wouldn't personally put me off. I Know others will disagree, but the LEAF is pretty reliable anyways, and as long as the car is fine at the time of purchase I wouldn't be too worried at all.
As for if it is worth considering I would say yes. The days of super cheap EVs are unfortunately over. Sub-£5000 you are only otherwise looking at the triplets which I would argue aren't really worth the amount they are going for since demand shot up, and otherwise a Renault Zoe or Fluence - Which will have a monthly battery lease charge attached to them. The LEAF is a good EV as long as the battery is healthy, which it seems to be at 12 bars (though do expect to lose your first one very soon) and the range is within your needs.
