Can anyone advise, probably those who travel to or live in Scotland, which cards/ systems I should sign up with please?
ive got a bmw i3s on order and I have registered with chargeplacescotland and paid £20 for the RFID card.
I see there’s a system run by Polar? But that’s £7.85 per month by direct debit. I’d only do that if it’s worthwhile doing so.
Will my charge place Scotland card cover polar points as well?
Are there any of cards I should apply for now?
I intend to get a pod point or similar installed at home but that might take a little longer to arrange. There appears to be two 22kw public chargers near me and 2 7kw.
any advice warmly welcomed to get me up the learning curve quickly
As @Fuzzer1234567 says chargeplace scotland is all you will need.
There are enough free to use (with RFID card) around so you don't really need Polar subscription.
install plugshare (if not yet) and you will be sorted
The chargeplace scotland card is superb.
I've never had cause to go near a Polar but I've used Instavolt points two or three times and they just need a contactless payment card and are so easy to use (worth the 35p/kWh if you're stuck)
As others have said ChargePlace Scotland gets you the vast majority of charging in Scotland.
Instavolt are expanding, but they just use your normal contactless credit or debit card. There are a few Polar, primarily in the central belt. If you're looking for a rapid charger near in/near Edinburgh I found them much less busy than the CPS chargers which often seem to have a queue of taxis. You can use an app to get them going (Polar Instant) and in time they should all be able to use contactless bank card, although I'm not sure of the timing. I was going to say Podpoint is fairly rare, but there are quite a few going in at big Tescos.
With regards apps, people seem to use Plugshare more than Zapmap in Scotland.
Sadly, you've joined the EV train just as most Scottish councils are introducing their own (very different) flavours of charging for charging. So expect the biggest minefield to be knowing what each charger will cost you.
Related Threads
1.7M posts
62.6K members
Since 2011
