1 - 7 of 7 Posts
hi all just had my new iconiq 38kw delivered apart from bit dirty alls good manged too get bluelink up and working car did check said alls good but the apps showing a red battery warning which i asume is for the 12v
any recomdationds as to do drive it charge battery or take too dealers,
did check battery its showing just under 13volts with car off,
13v is high for a 12v at rest - 12.4 to 12.8 is the normal range.
I'd take the car back to the dealers and make them own the problem in case it turns out to be expensive.
Zoe Devotee
12v showing just under 13v when the car is switched off tells you the battery is tip top. Nothing to worry about.
1 - 7 of 7 Posts
