1 - 20 of 29 Posts
Not really new news, but it's on the BBC again:
Another little dirty secret of the mainstream manufacturers. Maybe they could get Tesla in to help them with their security? :)
2019 Leaf 40
I wonder how long my new neighbour's new BMW will last? They were another brand that had cars go missing very quickly.
Insurers should be claiming back from manufacturers for these thefts. Might focus a few minds!
2017 Golf GTE
I'm sure that it would be specially annoying if you had paid extra for your keyless entry!
Definitely not
Definitely not new news (as indeed was suggested) - story has been going around for a couple of years : good to hear the BBC have caught up.
A very simple solution is to keep the keys in a metal keysafe rather than on the hall table when not in use.
I made a key box out of wood where I keep all the keys.
Then i used aluminium sheet inside to act as faraday box. both car and bike keys are perfectly protected :)
PS: Of course that if you want to be 99.999% sure that the car is safe then you use a signal scrambler but that is crossing the line of nonsense :D
I used a small pouch off ebay with Ampera and tested it worked - once I put key in correctly! For Zoe I press button (on home driveway) so passive unlock doesn't work. So far, Model 3 bluetooth entry hasn't been hacked and we will take precautions if/when that happens.
We leave keys in hall as if they really want our cars they can break in and take keys without any risk to us. If stolen through forced entry our insurance will pay.
2017 Golf GTE
I suppose that it depends on how much you want to keep your car.
We never keep the keys in the hall. When our front door was broken into at 4am, the alarm went off and the thieves fled having searched the hall only.
Replacing the front door and adding some bollards to the drive was much less hassle than getting a replacement car that is no longer made (GTE).
My preferred approach would be to add a power switch to the key. No power means no transmission.
If all car were required to have "pin to drive" we would not have this madness, as stealing keys would be a lot less profitable.
A car is replacable, I want to minimise risk to occupants of home. There will even similar age GTEs on used market to yours. With Model 3 I am not sure what we will do to protect it yet, but no reports of hacking.
The motion sensor (in key) approach works well and can be a retrofit, but does make keys more bulky.
In another thread someone posted a video of a mood to add a switch to a fob using a thing called a Battereed.
I'd do that if I could find the thing anywhere, but search engines insist on including 'battered' even when told I don't want that.
There is absolutely no reason why keys can't include a motion sensor to disable keyless when it hasn't moved for a few seconds. It would add well under a pound to the cost of the key.
It also surprises my that all keyless systems can't be set to disable keyless if the car is locked via the keyfob button. this would add zero cost and could be retro-implemented in the car's software.
And/Or a use the GPS so the button must be pressed when the car is at home, maybe allow keyless if the button has been used in the last 30 minutes to pre [heat|cool] the car.
However I still think one of the best options is to require all new cars to have a "pin to drive" in addational to the systems they now have.
1 - 20 of 29 Posts
