New ecar owner & finding it steep learning curve :-(
1460 Views 14 Replies 8 Participants Last post by  evbuyer2020
Hi all - to be honest I just jumped into the ecar purchase and bought the cheapest I could find. I now find that I should have learnt more about... well, everything. However I didn't so can I ask some basic questions here? Like if I have a Renault Zoe with a 22 kw charging connector, is there anyway I can get an adapter to be able to charge at 50 kw fast chargers? Thanks. Patricia
1 - 15 of 15 Posts
...Like if I have a Renault Zoe with a 22 kw charging connector, is there anyway I can get an adapter to be able to charge at 50 kw fast chargers? Thanks. Patricia
Afraid not.
Afraid not.
Thanks... at least I know now.
Most rapids have three cables and supply 50kW CCS and Chademo and 43kW AC(for EVs such as Zoe). With some, rather than an AC tethered cable, there’s a 22kW type 2 socket on the side of the rapid, and you use your own cable.
Reactions: 1
Look out for the free 22kw charge points that are gradually being installed at Tesco's. Very useful for Zoe owners!
Whilst not as fast as a 50kW CCS, I find in my Zoe that once the battery reaches about 60% the charging speed is similar as the charging speed of the rapid charger slows down. .
To be honest, a rapid charge Zoe 22 wouldn’t charge much faster than the with standard 22 kW AC charger.
Depends what you’re trying to do. Do you have a home charger?
Only the very latest 2020 Zoes can use DC chargers, and even then it's a £1000 option not available on the base spec.
What part of the country are you.
22kW is pretty much the Scottish defacto AC charging standard for 3 phase public chargers: you would have plenty of choice.
Reactions: 2
Would much rather have a Zoe over my current cheap EV as loads of 22kWh posts around whereas most 50kW Chademo/CCS are sadly broken where I need to charge on longer trips.
I'd also get myself a nice long charging cable to plug into the 22kW socket on rapids. That way I'd get around the issue of Chademo/CCS cars hogging/queueing at the few working rapids :)
Besides 22kWh posts cost half [or less] than a rapid (y)
Reactions: 1
The west of Ireland... you really have to do your homework if you're going anywhere other than Dublin!
No home charger :-(. However, I have learnt from a 20 reg VW ev owner (my car's a 19 reg) that the Zoe charges much faster than the VW at a 22 kW charging point! Who could imagine!
Wow! Again, so much to learn... Thanks for this.
Thank you.
Thanks - good to know if I travel to the UK after this madness. Sadly, Tesco are using the ESB to install their chargers here in Ireland so not free, unlike Lidl (where I now do all my shopping ;)).
It's the opposite here. Tesco are free. But Lidl are not!
Reactions: 1
1 - 15 of 15 Posts
