I took delivery of a brand new 70reg EGolf on Tuesday and have charged it fully through my front room window on a normal 3 pin household socket. It took a while to charge, which was fine, but when it was fully charged it said I had a range of just 111 miles! Now I know real world mileage is around 125, but I was pretty sure the range would be a lot higher than that with a full charge! Is this normal for a new car? It is cold today as I write this, but it was mild a day or so ago when I finished charging it. Any help gratefully received. Merry Christmas.
That estimated range is based on its previous usage. Don't worry about it; just drive normally without risking a flat battery pack and the range value will creep up.
Thanks for that. Do you keep your car topped up everyday? Also, what EV do you have and if you charge it at home do you use a proper charging point or a standard plug? And lastly, how much does it cost for a full charge?
I’m really not sure if it’s worth paying £450 for a charging point if running the cable through my window and plugging it into a standard socket does the job. What would you say? Thanks again to you all for your advice. I’ve only ever had standard engines cars so this is all very Greek to me despite all my research.
Others will have their own view but I always recommend going for the 7 kW home charger. Once installed it lasts for many years and fits all modern EVs, using the type 2 connector. A grant is still available towards the cost of purchase and installation - not sure of you had factored that in with your figure. Wether or not you use the 3 pin plug or a 7 kW home charger, it is possible in many homes to switch to a special tariff for EVs, for example Octopus Go which gives a good day rate and four hours overnight at 5p per kWh. That means you can charge your car for just over 1p per mile of travel.
I had an e-Golf for 12 months and currently a Tesla Model 3. Sounds like you have made a wise choice for your journeys. I echo the sentiment of others - just put climate control on and at a comfortable level and enjoy the car.
Mine full is saying about 78 miles at the moment. Last usage was a couple of weeks of short runs, lots of preheating, plenty of heater use on the move so efficiency very low. As said, the GOM is based on previous usage so unless you’re doing the same trips all the time it’ll inevitably be out. Don’t worry about it!
If you're only doing 12 miles a day plugging in at work on the granny charger will be all you need. I wouldn't recommend charging fully from the granny every day but if you are only needing to add a few miles worth of charge each day I would think that's fine.
I have a wall charger at home, wouldn't think of not having it as often so longer runs where the car needs fully charging but I also use the grant charger at work a couple of times a week, it's free and I need the charge to get home.
Cost wise I'm with octopus on the 5p for 4 hours each night. An empty battery needs about 30kwh, more of its a new battery and completely empty, but at 5p per kWh it doesn't cost much.
For the ID3 VW are recommending charging to 80% and discharging to 40% if that's all you need each day, to help the battery life. Many on here will say just plug it in and use it, but there are plenty of others, myself included, that wouldn't charge to 100% every day if you don't need to.
We have done 53000 miles in our Golf over the last 3 years so often have to charge to 100% but when we're only doing short miles I only add what I need to keep the battery above 50%.
@Baldylocks65 must have one of the last e-Golf's registered in the UK!
62.3K members
