rating out of 10 (10 being the highest score)
  • Total voters
    10
1 - 20 of 50 Posts
Hi, my name is Chris, the owner of EV chargers direct ltd a new UK company
we have two new chargers coming to market in the next couple of months please see the photos attached of one installed at my house. just wanted some feedback on the unit if possible?.
its: mode 3, type 2 socket, built in type A RCD, 230v 1-phase 16 amp or 32 amp charge (3.6kw or 7kw), key lock, led display, lights around edge showing charge status too, wall mountable, metal back and sides and acrylic front. will be around the £350 + vat price. we have applied to get it approved from the 'office for low emission vehicles' (so will be able to use grant with it) but that is not confirmed yet I will update if and when we get approval.
please let me know what you all think of the look, price, features etc. our website is being built, www.evchargersdirect.co.uk
you can also email me for documents, more info etc at [email protected]
Thank you,
Discussion Starter #2
Thank you,
Hi Ryan, thanks for your positive reply. Yes, were developing a 22kw rapid charger (3 phase) but will also be a wall mounted unit and look similar to that in the photo. and also a twin socket version (7kw and possibly 22kw) that will be similar. with the posts do you mean public charge points or just for domestic? at the moment were concentrating on domestic but in the next 6 months, depending on how it goes with sales etc we want to develop a work place/ public charge post, it will be 7kw and 22kw at first then we will move into the bigger 50KW and up level afterwards.
cheers, chris
the public chargers will take more time to develop as will have to incorporate GPRS or Wi-Fi communications and a RFID card scanner,
the EVO 16 and EVO 32 will also have a Wi-Fi ready variant coming later too.
thanks, chris
Driving yet another EV!
It looks nice, but I have a few comments:
1) Is the "light show" programmable in any way? There will be locations where you might not want to draw too much attention to the charger, plus it may get irritating to neighbours (if it is opposite a lounge window for example).
2) You have an emergency stop button on your charger (though it is half hidden which seems to defeat some of its purpose) - these are pretty much unknown on all except rapid chargers. Do you really need this?
3) Is the key switch waterproof? I see there is a cover that can swing down to protect it. What is the implication if the cover is left up?
4) The bottom of the box in the picture is open. This is not a good idea as the RCD is not waterproof!
Hi Thanks for your reply
the RCD is in a recess and the switch only comes through the casing, it is sealed in place, it cannot get rained on etc and has been certified IP54 for outdoor use, because of the recess design and the water shedding properties of the casing.
the key is weatherproof (IP54), it is sealed internally, the flip is more for aesthetics and so to reduce risk of ingress in the event of a high pressure jet from a hose etc.
The light are on all the time when the key lock is in the on position and change colour depending on the status.
we are looking into installing a switch at the bottom to choose between lights on or off and will likely include this feature shortly.
Many Thanks, Chris
Discussion Starter #8
with regards to the emergency button is is not required to meet regulations we have added it as an extra failsafe for rare occasions, for instance, lock/button not working, unit is ripped from wall by vehicle collision etc. your right in that it is not a necessity but may come in handy one day
As has been discussed already, the light show will prove unwelcome to many users. My Rolec has a very modest single small light showing either ready or charging. But even that is an attraction to curious passers by advertising somewhere for a bored antisocial yoof to come and investigate. I have stuck a 1" length of white plastic water pipe over the lamp so that it can only be seen from head on and not from an angle. I would definitely give your unit a swerve simply on those grounds alone.
Do OLEV chargers still require cellular data reporting?
One reason why OLEV supported units are expensive is because of the additional complexity added to meet the reporting requirement. As far as I know, nothing has ever been done with the data collected. If the data is even collected....
Might be worth submitting another FOI request. Don't want to rock the boat but maybe it is time for OLEV to stop requiring data reporting. If they aren't going to do anything with the data, what is the point of adding the hardware?
Lights are always a pain - even my pod point single led is too bright really and serves very little purpose as the car is telling me what I need to know. What I would really prefer is some kind of cumulative kwh meter that breaks down how much Im putting in my car daily, weekly,monthly and total. I cant believe they dont all have these as standard. Obviously if carwings worked properly I wouldnt need it. I did see a post where someone had installed a meter on their podpoint breaker circuit.
Discussion Starter #20
Yes, you can put a meter between consumer unit and charge point but also looking to add the function you describe on our wifi ready next generation and it can be looked at remotely
1 - 20 of 50 Posts
