1 - 12 of 12 Posts
Hi, I'm using a new wallbox with my Zoe ( Q210 with 41kWh battery ) , but after 60/80 minutes it stop charging.
With CanZe I can see the following errors
127438
This is the value while charging
127439
I have the Zoe from 2 years and I used it always with Flexi-Charger Renault, and with 22 and 43 kW charging point with no errors.
Can you help me? Thanks
EDIT: This is the wallbox WallBox Scame 7.5 kW and it is installed in a company with no problem to use only 7.5kW
Leakage HF is a hint. Try to capture leakage graphs. I think fairly reasonable values are DC 1mA, LF (50 Hz) 50mA, HF (chopper frequency, the high pitch noise) 170 mA and EHF (HF harmonics) 80 mA when charging on a single phase outlet like the one you post.
Thanks!
I will try on Monday, but the only problem is that I charging the car during my working time, so I can't check the graph during the problem, but only when I'll return to the car.
Thanks again
I tried this morning with no errors
This is the value at starting charge
127560
And this is after 4 hours, before I stop the charge.
127563
My take: HF slightly high, not crazy (AFAIK the cutoff is 300 mA). So yeah, what can we say?
Tomorrow mornig the charging stop after 2 hours.
I back to the car after 4 hours and tried to charge again.
As you can see the value start from 200 and increase up to 300. I stopped it and tried after 5 minutes in a EnelX 22kW charging point and after 5 minute at home with 10A Renault Flexicharger.
Only with the SCAME wallbox I have value so high....
What I need to check: WallBox or other?
Thanks.
127642
So it is the HF, as I remember 300 mA to be cutoff value, and the earlier end of charge message hinted to it. Now here's the problem. HF leakage is created by the capacitive coupling between the internal wiring (esp in the motor) and the chassis. I heard of one other case in Belgium that ended up R offering the client another car. And they really didn't slack, had people flown in from Paris if I remember correctly. There is no way I can explain this other than a really crazy fault in the car, or ringing in the cabling, especially if it works fine on another 7.5 kW, single phase charger (note that all these details should be the same).
An extra filter may work, but it's not yours I think? It's most probably not the charger in and by itself, as basically it's just a chunky relay passing the AC to the car, but a freak combination of wiring, closeby mains transformer and "earth rays". If you are really keen on using this charger, i.e. because it is free at your employer, my advice would be to get a 16A single phase charging cable and use it at this particular charger. It will reduce the power intake of course.
Not an ideal situation and slightly frustrating, but it could do the job and would avoid an endless back and forth between Renault, SCAME, the electricity company, probably your employer, which could go on forever with no guaranteed outcome.
Discussion Starter #9
If it is a car problems, why it is the first time that it appears in the last 2 years?
I charge with no problems with the same cable on 11kW, 22kW( only 180 leak HF), or 43kW etc etc. It is the first time that I use a 7.5kW . It is at my work place and until now I used always the Flexi-Charge Renault a 14A ( with magnet). In 2 years at my work place only 2 time I founded the car with error.
You say that if I use 16A it will reduce, so if I charge 64A at 43kW I will have a huge problem, right?
I can ask to electrician to try to add filter, but what kind of filter I have to ask for?
I can belive that the problem is mine. I can understand that the car is not perfect, but I never had problem with other Charging point! So I think that it is possible to do something to mitigate this problem.
Sorry if I'm insistent, but with this new wallbox I can charge in 4 hours 60/70%, with 16A I can charge only 25% so I need more day to full the battery.
Thanks a lot for your patience
As I said, the way I see it, it's a freak problem. All your other examples of no-problem charging have different parameters, especially re 1 and 3 phases - which makes a huge difference internally ( 1 phase requires boost mode, 3 phase buck mode) -, and charge currents. In theory, capacitive leak current is, everything else being equal (!!) dependent on voltage, not so much current, which kind of negates my theory. Then again, things are usually not as simple as a single-line theory.
The 16A suggestion is just that: to try if it at least gives a short term workable solution without massive delays and costs. I fear an "it should just work!" line of thinking, while totally reasonable, won't solve your charging "stress" any time soon.
No. I understand the line of thinking, but for instance the 3 phase charging does an entire reconfiguration of the internal charger.
I'd say a line filter that suppresses everything above say 500 Hz massively, as I suspect ringing/resonance of the 10KHz chopper frequency fed back into the grid. But I honestly admit, it's a "shooting from the hip" suggestion.
Discussion Starter #11
I charged 2 more times. I charged in the afternoon from 14:00 until 18:00 an it works. At start the value was 270, but at 18:00 the value was 150...
So I thought: what is the difference?
There is a photovoltaic system, about 22kWp, with a three fases inverter. In the afternoon, in this period, the sun sets quickly.
Could this be the problem?
Absolutely. If possible I would check if there is a correlation a bit more. It does make sense.
If so, your best and cheapest bet is an extra filter. I know Renault has installed a few in problematic chargers in the UK, maybe someone here can step in who has one for a type or something. Your sparky might know too.
1 - 12 of 12 Posts
