1 - 14 of 14 Posts
Hi all,
After recently going through the pain of finding an installer to fit my own home charge-point, I thought I'd create a website to make it much easier for everyone else and to possibly help in the adoption of EVs'.
The website allows you to search for all local installers who are able to apply for the OLEV grant on your behalf. I've tried to make it as intuitive as possible, and I've also created a few posts detailing tips, eligible vehicles and OLEV criteria.
I hope you find it useful, and if you have any feedback, happy to hear it.
https://www.chargemyev-home.co.uk/
Some Rolec sponsorship here based on the images used????
Hope everyone realises that the OLEV database is in a mess following July change of rules as to charger minimum technical requirements.
Many of the installers listed will have never have done an installation and what is worse, will have no idea about the technical requirements and don't possess adequate testing equipment. Be aware!!
i had my home charge point installed by a company called Energise Energy Solutions. they are based near Doncaster but told me they have engineers all over the UK and are independent company so have a few different options for the charging points. the work was done quickly and they even sorted my grant out!
Thanks for all your feedback. The website uses OLEV data but hopefully makes it a bit more interactive and intuitive. There's no doubt been a big shake-up since the 'Smart' aspect of home chargers has been introduced since July 1st, and there are a number of omissions in the data, but certain aspects such as installation coverage classifications have definitely improved. Fingers crossed they're going in the right direction.
I wish we were being sponsored by Rolec, but I found a lot of copyright-free images weren't of sufficient quality, so ended up taking most of the photos for the website myself. In terms of technical requirements, it's a really good point. I'll try to flesh out some of the posts to make sure everyone understands they need to research their selection of installer thoroughly to ensure they get the best outcome.
It seems very good. The map is great (but shows how few there are in my area - two, both about an hour away).
This is what OLEV should be producing - not just a list you might be able to check an already chosen installer against.
OLEV should for each named installer list how many installs they have done, and collect customer feedback as part of processing the grant, then publish the adverage of the feedback for each installer.
Discussion Starter #9
If you only have two, try searching other coverage areas close to yourself, as most installers cover multiple regions.
Also, try installers with country or national coverage. You should hopefully be able to find a few more to start building a prospective list.
Discussion Starter #10
Great ideas. OLEV seems to have gone a bit quiet recently, so not sure if this is down to the current political landscape, or if there is another reason. Customers can certainly leave reviews on the website. Once there is more than one review, it will start to generate an average score (which can then be sorted).
Discussion Starter #11
I've just added a home charger comparison table to the website. All of the chargers listed comply with the July 1st regulations and are OLEV approved. There are a few not listed, mainly due to lack of availability or pricing.
The pricing side of things has been a challenge, as I've tried to include the unit price only (incl. VAT but not the OLEV grant or installation costs). The problem is, some manufacturers only include the unit and 'standard' installation costs together (which I've highlighted). Others include earthing, and some do not, so take the pricing as an indication and not hard fact.
If you feel anything is drastically wrong, let me know here or leave a comment on the website. I'd also be happy to hear of any suggestions which you think might be useful. I've tried to keep the table fairly concise, as huge tables of information can be a little bit overwhelming, and don't necessarily scale that well on phone browsers.
https://www.chargemyev-home.co.uk/charger-comparison-table/
Discussion Starter #12
Ok, I've been busy the past week or so adding a few more bits and bobs.
  1. The website is updated with what was the latest OLEV installer data (there's been a further update today).
  2. You can now filter results by the manufacturer. So for example, if you want to find Rolec installers in the East of England, you now can.
  3. I've updated the charger comparison table with prices purely for 7.4 kW socket options (where available). This is to hopefully give a better 'bang for your buck' comparison than before.
I'll keep you all posted with any further updates.
Discussion Starter #13
A few more updates:
  1. The website has now been updated with the latest OLEV installer data (27/09).
  2. Instead of searching by installation coverage area, I have now changed this to charger manufacturer.
  3. After selecting your preferred charger option, you can filter either by which is nearest and/or installation coverage area. As a result, your prospective shortlist is dynamically broadened/narrowed.
Enjoy!!
1 - 14 of 14 Posts
