Would installing a commando socket eliminate all safety concerns? I guess on top of that I’d also need a commando charger?
Would installing a commando socket eliminate all safety concerns? I guess on top of that I’d also need a commando charger?If your getting a sparky in to fit a dedicated outside socket get a commando socket.
It's the cable you're worrying about, so he's gonna have to run one from the CU anyway.
Depends on how smart you want it to be, and how "standard" the install is (I.e. is it a short external run from the consumer unit). A podpoint on a standard install is sub 500 pounds. A good smart unit like an Ohme is around 600.Yeah I agree. Although, we wouldn’t do that short term as we plan to do some structural work on the garage.
How much are dedicated charging points (incl installation)?
Sounds like your garage has been tagged onto your kitchen ring, I wouldn’t charge a car off that if I were you!Yeah I agree. Although, we wouldn’t do that short term as we plan to do some structural work on the garage.
No is the short answer mate, earthing matt-e /garo mini cu, earth rods..... Has your granny cable got a commando male end? Or is this further cost?Would installing a commando socket eliminate all safety concerns? I guess on top of that I’d also need a commando charger?
Who is your electricity supplier? Ohme cables are discounted via Octopus.Would installing a commando socket eliminate all safety concerns? I guess on top of that I’d also need a commando charger?
It gets complicated.
Well yeah but I'm not going to lie to him.It does but if you are looking for a temporary charging solution that isn’t going to burn your house down then a commando fitted on some 10mm and a portable charger is a dramatic improvement on where he is now.
This is true, you need a charge point.Well yeah but I'm not going to lie to him.
Running 10mm to a commando socket then making sure he's got a commando lead, he won't be far off the cost of a fitted charger.
A lot of granny chargers have a temp sensor moulded into the plug because theycan overheat.Thanks everyone. Yeah I think I’ll plug into the house as soon as I’m home from work for 4 hours then unplug.
I appreciate everyone’s input massively. How much is a charge point? Is it overkill for a PHEV?
Also, no. The granny charger does not have a commando end
Normally if your within a "standard" install a national firm (bp pulse, podpoint, Andersen, zappi) will fit it, claim the olev grant for you and charge you between 400 and 1k.I don’t know anything about charge points, how do they work? I mean that in terms of installation and etc
I have been charging one of mine almost exclusively from a granny for 5 years probably. Obviously I would like to think I would notice any signs there was something amiss. 10 amp constant is within the design specs of a socket.I am no electrician, I just go with the general advice that it is not a great long term bet. I am sure that a proper electrician will be along soon and give you some proper advice. Going in your favour is the fact that the garage is detached from the house and that because it's a PHEV, the battery is not enormous. But the more you can lean towards a dedicated solution the better. Safety rules. Don't take short cuts.
Not for sustained loads at 10 Amps.10 amp constant is within the design specs of a socket.
You run your hot-tub off a three pin socket at more than 10 Amps? For 24 hours?My hot tub can easily pull more current for a longer time.
Yep, maybe not longer than 24 hours but easily 10 hours and beyond a certain amount of time then the thermal load doesn't really increase. That's why the BS test uses a minimum of four hours under load to achieve thermal stability.You run your hot-tub off a three pin socket at more than 10 Amps? For 24 hours?
