This is going to be one of the issues with mass take up of EVs. Give someone a lead with a 3 pin plug on it and the majority of people are just going to plug it into the most convenient socket with no real thought about load or how that particular socket is fed.
The benefit of a new dedicated circuit, be it a EV specific wall box or a properly installed commando socket is it's a known quantity with limited points of failure. That socket in the corner of the lounge that the granny charger is plugged into before being dangled out the window is drawing a large continual current through a circuit with many points of possible failure. Is it a spur, and from where using what? If it's on the ring, when was the last time it was tested for continuity around said ring or is it pulling 10amp through one half of it, and what else is on that half?
