Thanks for that - great with the pic. Just about to google ’fuse tap’!I have the 622 variant and installed it myself using Nextbase hardwiring kit, it you drop them an email they’ll send you the correct fuse tap with the correct fuse rating FOC.
If you want a switched live use the 1st fuse on the left, for a permanent live use the 5th fuse down on the left. You would need to enable parking mode on the camera, otherwise it will stay on. View attachment 140312
I’ve never had any problems with battery drain and mines connected to a permanent live.
OK - looks like I already bave a ‘fuse tap’ (😂)Thanks for that - great with the pic. Just about to google ’fuse tap’!
By ‘switched live’ do you mean it only comes ‘on’ with the ignition?I have the 622 variant and installed it myself using Nextbase hardwiring kit, it you drop them an email they’ll send you the correct fuse tap with the correct fuse rating FOC.
User manual.Starting to make more sense! Thanks to all, now know what a fuse tap is - and that I’ll need a smaller one for the Kia!
I see the top left, and 1 up from bottom left are both ‘Spare’ (10A). How does one find out if they’re permanently live or Ignition on only?
I don’t think that the correct fuse tap, that’s looks like the standard size, Kia uses a smaller one than that.OK - looks like I already bave a ‘fuse tap’ (😂)
That’s correct 👍By ‘switched live’ do you mean it only comes ‘on’ with the ignition?
Thinking I’d prefer that to the risk of inadvertently flattening the battery if someone had played with the camera setttings.
Would that be the paper or on line manual?User manual.
That's interesting, my kit was supplied with two different sized fuse taps and fuses!OK - looks like I already bave a ‘fuse tap’ (😂)
A later model perhaps. My 312GW a few years old now - just dug out the box and only other accessory in there is the cigar lighter socket lead.That's interesting, my kit was supplied with two different sized fuse taps and fuses!
John
Mine also came with 2, neither of which was the correct size.That's interesting, my kit was supplied with two different sized fuse taps and fuses!
John
When parking mode is enabled the camera stay on for 5 minutes then enters parking mode, that’s provided you are connected to a permanent live otherwise it will switch off as soon as you power down the car.Credit to Nextbase - correct size tap and fuse delivered free of charge today!
Camera now connected to top left fuse slot - just checked and it does go off after the pre set 10sec delay when I turn off the ignition!
Still to set up Parking mode - as I understand it should enter Parking mode when power supply is cut. As a point of interest how would Parking mode be activated if the live feed was permanent and didn’t cut off when ignition switched off...?
Thanks again for the help! 😎🙂
