1 - 3 of 3 Posts
Just fitted today some uprated bulbs for my 2018 Leaf 40 Acenta.I changed the outer bulbs, H11 type, to Ring Xenon 150. The Ring bulbs cost £19 a pair. Fitting them was a bit fiddly,man hands too big. Anyway, took the car out this evening in the dark and was pleasantly surprised with the improvement. Much better light spread noticeable around town with dip, main beam was slightly better. Worth a look if you are on a budget as £19 for a pair seems good value.
Discussion Starter #3 (Edited)
I bought mine through EBay. If you enter within EBay a search for Ring Xenon 150 H11 bulbs you should find them listed at £18.95 inc postage. They are a bit fiddly to fit.The bulbs to change are the outer one’s, twist the round cover off, then turn the bulb 45 degrees and carefully pull out.If you have small hands that would help !. Simon.
1 - 3 of 3 Posts
