1 - 16 of 16 Posts
Eniro 4+
Had my charger fitted this week by a company that shall remain nameless. An additional electrical box needed to be fitted adjacent to my fusebox (for reasons unknown to me, possibly because my fusebox didn't have any additional slots in it? )
The noise it makes is horrible!
I can hear it from my living room! Would you accept this? What else can I do about it?
Leaf 24kWh
You wouldn't want a car charger connected as part of your normal Consumer Unit - not a good plan.
The noise, however, does seem quite excessive.
Eniro 4+
Agreed. After a little reading it sems this 'thing' is fitted as part of the earthing, thus removing the need for a rod.
I'd rather have an earth rod than this bloody thing though!
Its turned off at the breaker currently. I'll just turn it on when the car needs charging. Less than ideal for a £1000 install but I guess I'm stuck with it.
Eniro 4+
I think I'm just going to leave the breaker turned off until I want to charge the car. It'll only need a charge once a week at the most.
That'll save my street being illuminated by the ridiculously bright led on the wallbox charger that I can't seem to turn off or control.
Given I've just spent almost a thousand quid, dissapointed is an understatement!
EVEZY code -£50 off: d409e
Or both podpoint and zappi (I'm sure others) require neither..
I'd be annoyed if I could hear that all day..
Eniro 4+
I'll have to put up with it. I can't afford to bin it and buy a zappi (I don't need it's fancy features to be fair) .
Because of the floodlight fitted to the front of the wallbox charger I'll just leave the breaker on the matt:e tripped until I need to charge the car.
Less than ideal but I see little other option without considerable further expense.
What charger have you got? Was the Matt:e even needed?
That's a decent plan.
Gaffer tape / Duck tape.
Welcome to being an early adopter of emerging technology. :)
Eniro 4+
Discussion Starter · #14 ·
Yeah tape will work but it won't look pretty. I might have a try at it. It's a joke you can't select the light to off.
Like I said, I know the cost is miniscule but it's the principle (along with the looks!). Ev's are supposed to be environmentally friendly etc.... I charge mine every 10-14 days but I've got to have a light illuminated 24/7 to do that. I dont know what they are thinking.
It's the contactor in the matt-e box (that provides the required open PEN fault protection), as above, others have noted the same problem. There are silent contactors available, not expensive, either, so I've no idea why matt-e choose to use such a noisy one.
1 - 16 of 16 Posts
