1 - 7 of 7 Posts
Hi!
I got a used Audi A3 Sportback 1,4 TFSI e-tron S tronic 2015 last fall and in the beginning I could change the charge mode between full EV, hold battery o charge the battery. Now for the last couple of months I have not been able to do so as it is "grey" in options where I should be able to change it. This is annoying as I would love to use the charge mode when I drive on the high way and I would then have full battery when I come in to the city. Any ideas what I should do? Or do I just need to go and get software updated?
- Eetu
No it stays as gery all the time. I've tried both with full batteries, empty batteries and while driving.
Odd. Sounds like a diagnostic check needed. Do you have access to VCDS (needs to be the latest type for the phev batteries.) May be worth searching/posting on the VW golf & Passat gte forums.
Do your car regenerate when you slow down/brake in hold mode (does dial on power gauge drop into lower zone)?
1 - 7 of 7 Posts
