1 - 20 of 41 Posts
Banned
Does anyone have an EV and Solar panels AND currently getting paid for both generating electricity and exporting?
I'm in that situation and looked at Octopus Energy as I was interested in their 4 hour charging for 5p kWh tariff. I've asked whether it's possible to get paid for exporting electricity AND get that 4 hour cheap charging and I can't get a clear answer out of them. They seem to be suggesting I can have one or the other.
In my case I also have a Tesla Powerwall 2 which is usually 100% full every day and runs my house at night. If I plug my car in at night then it drains the Tesla battery and finishes charging by taking power from the grid.
So what I want to do is use the charging schedule to only drain 50% of my Powerwall in the early evening and then finish charging at the 5p kwh rate over night AND still get paid for exporting spare electricity. If I can do that then I'd be charging my car for practically free from March to November
EVEZY code -£50 off: d409e
Octopus do not allow you to have Octopus GO and their export (outgoing) tariff.
You can however have your export tariff with another company.
E.g Octopus Go for import. Bulb for export payments.
134736
Banned
I didn't know I could mix and match.
That means I can leave my export with my current supplier nPower and switch my electricity to Octopus Go.
I'll contact nPower first to make sure.
Thanks for the quick response.
Leaf 30kWh, Outlander PHEV
Yes Octopus pay you export tariff. Their SEG payment is 5p/kWh assuming you have MCS certified installation
Banned
Yep. I export my solar via Green Energy uk and import via Octopus go Tarriff. No battery storage yet though. I would have thought in the winter months Nov-Feb you would top up the powerwall to full @ 5p from Octopus Go 12.30am-4.30am and use that leccy from 4.31am to sun up and during the day when the weather is rubbish and no solar generation so you are paying 5pkwh rather than the 13p+ day rate?
What happens to your FIT payments if you opt to go for an export tariff?
For those who had Solar fitted before FIT closed, you can opt out of deemed export and still receive your generation FIT.
jim5452
<<<<For those who had Solar fitted before FIT closed, you can opt out of deemed export and still receive your generation FIT.>>>
Now I am trying to get my head around that, why would anyone want to do that, we had panels fitted in 2011 and use almost all our generation except for a few times in summer.
I can only think of people who do not use timers, smart switches and are absent for long periods
Peugeot e-2008 GT-LINE
How about switch to agile and then use your power wall to power house at peak time when expensive unit rate and then use cheap/negative rate to charge car and powerwall after that.
Banned
Discussion Starter #11
I'll look into that.
I did the math a few years ago against economy 7 and found it was far cheaper to just let the Powerwall charge up from solar and get free electricity rather than have it charge with cheap electricity overnight. On average during the year I'm 75% self sufficient. The percentage drops from December to February. From April to September I'm 100% self sufficient and don't use the grid at all.
However all that's changed now I have a full EV hence why I'm looking at this Octopus thing. I'll have to read up on agile and run a few scenarios.
I was one of the last people to get FIT and it's pretty low - about 4.5p a unit. However it's guaranteed for 25 years and goes up with inflation so I'm not opting out of it. I use most of my electricity and still get paid for generating it regardless of whether I use it or not. I use Good Energy for my FIT payments and use Octopus Go for the supply as well as using my zappi which charges off surplus solar when I'm in so don't export much at all
We still use gas for heating and I charge my car overnight, so sometimes export close to 90%, e.g. yesterday.
134744
134742
134743
You still get the generation FIT.
Also just fyi, FIT is 20 years for anyone who signed up after ~2012, 25 years for those who signed up before.
What???? NOOOOOOOOO. Oh damn. Hadn't noticed that in my documents. I'll have to go and check but I'm sure you're correct.
Banned
Discussion Starter #16
Yes it's 20 years but the rate goes up in line with inflation. I'm getting 5.5p for export and a 4.5p for generation. The generation payment ceased in 2019 for new installations.
Kia eNiro 4+, White
I do things a bit differently.
I have 4KW of solar
19KWh of house batteries
A small PHEV - although I have an eNiro on order
My house uses a lot of electricity - parasitic rate of around 1KW per hour
I am on the 50+p / unit FIT rate + 50% deemed export. I actually export very little
I am on Octopus Go Faster @ 5.5p/unit
I have a basic Chargemaster EVSE
Car charges during the cheap rate only.
Batteries charge during the cheap rate to as much as they can hold (during the summer I reduce the max grid charge)
During the day any solar is:
1. Used by the house
2. Charges the batteries
[3. Not yet - but will charge the car - if it can take any charge]. Need to change the Chargemaster first
4. Export to grid
I don't export a lot!!
Sean
Banned
Discussion Starter #19
I have 4KW of solar
4. Export to grid
Sean
Very nice. I export tons. Use very little during the day. Powerwall is full just after lunchtime. Usage goes up when I play call of duty on my PS4 :) and occasionally when the wife puts the washing machine on. However that will change now that I have a full EV but the EV will charge mostly at night. Still trying to figure out the best combination of solar, battery and EV charging. So many variables!
1 - 20 of 41 Posts
