Currently on Go and looking at switching to Intelligent.
As far as I can tell you get 2 hours more cheap leccy and at a reduced price by 2p per kW.
So couple of questions for those already using Intelligent GO, if I may.
Each time I want to charge the EV I would have specify the charge? Do I specify the number of kW I want, the percentage battery charge I want or the amount of time I need it to charge for?
If a full charge takes longer than the "cheap-rate" 6 hours, does it stop charging at the 6 hour mark, thereby only using cheap-rate leccy?
I have read that Octopus will charge the EV to the level requested by the requested time not necessarily in the "normal" 6-hour window but still only charging cheap rate. So that means the Octopus app controls the charge not the Zappi. Can you set the Zappi to control the charging times anyway, ignoring the Intelligent charging?
If Octopus can change the time that the EV is charged, how does that impact using the 6-hour period for washing machine / dish washer equipment? If they move the times for EV charging, how do you know when to switch on the white goods to make use of the cheap-rate leccy?
Thanks in advance for any answers to these (dumb?) questions.
