Hi,
I'm sure there are answers to these question but I can't find them on the forum.
I want to charge only with off-peak electric (even of it doesn't get 100% charge), and manual preheat the car from battery. My off peak rate is 00:30 to 04:30.
Is this possible?
Also- how does the i3 work out when to start charging if the departure time is set?
The car seems to connect to the power briefly when you initially connect it- is it at this point it works out the power available (16 or 32amps) and then works backwards from the departure time to see when the start time for charging should be?
Is this possible?
