Biomass already does. We burn a lot of imported wood chippings - very clean🙄. There are new developments in nuclear that should allow them to match demand closer using thermal (liquid salts) storage. Thermal storage in peoples homes (yes storage heaters) can also level up demand. Wind, clearly is too unreliable and therfore gas will be needed well beyond 2026. Hydrogen is a gas so this too could replace natural gas. Solar is pretty much an irrelevance.
Not sure that solar is an irrelevance, it peaks at near 10 GW and is still being developed. Double sided panels in zig zag vertical arrays and there is a Finnish outfit selling domestic trackers which vastly improve the time throughout the day at peak power. Wind is intermittent but watch out for the Crown Estate Scotland’s new bidding round which could bring in the area to the west of Orkney and Shetland where it is always windy. Rolls Royce mini nuclear reactors probably use the same principles as reactors in nuclear submarines which are capable of going from idling to peak power in seconds, but the cost of clean up remains a big issue. There are a bunch of nuclear submarines in Devonport that are ‘cooling’, more likely that the bottoms will rust and the reactors will have to be recovered from the bottom of the harbour!
It is all going to be about time of use in the end with hydrogen and fertiliser production soaking up big surpluses and not being produced at calm times.
it is quite conceivable that there could be 50 GW of wind turbines by 2030/2. Some of the old onshore turbines will come to the end of their life and the wind farms will be ‘repowered’ so old turbines and towers rated at up to 2 MW will be replaced by 4 MW machines. This is already happening in a limited way where permission is being granted for removal of a few old to provide extensions to existing farms. Similarly the earliest offshore wind farms will be due to be replaced 2030 onwards and the speed of improvement there has been astonishing. SSE will be using 14 MW machines in the Dogger Bank wind farm and folks may not have noticed the sleight of hand, they were awarded cfds at about 4p a kWh for 454 MW of the Seagreen farm but are building over 1050 MW at that site, the remainder without any support.
Of course floating wind will become very important, sea bed conditions have precluded wind farms off Wales, early development got halted when poor conditions for piling were found.
Development is required for the flexing of high voltage cables and anchoring systems in harsh (very windy therefore excellent) conditions for floating wind.
The published data on offshore development takes some studying, The Crown Estate leases the seabed and it can take time for proposals to be worked up to the point where it becomes known what developers want to build. Then planning gets in the way, both offshore and onshore including the need to cater for birds, whales, low flying military aircraft and ex American presidents! But over 3 GW is currently being built, another 8 GW is in the approved category some 4-5 GW of extensions to existing wind farms is in the planning and pre approval stage and over 8 GW in feasibility stages. Another 20 GW of offshore leases are coming up for auction in the next 12 months. The wider the placing of the wind farms the less likely for there to be a total calm.
