1 - 20 of 66 Posts
Hi all
My 2012 Volt just threw the above error. Torque pro shows the follow codes...
130456
It was charging quite happily via the Zappi yesterday, but threw the faults when it was powered on this morning. It's been very dry and warm recently so I'm guessing it's not the charge port. The 12v batt has been on a ctek charger for most of the lockdown A quick check of the coolant level and it's well above the seam as it should be. This makes me think it's the coolant sensor...
Is there anything more I can do to check/test/fix before ringing Bellingers?
Thanks.
Roger
Edit: I forgot to add that I tried resetting the codes but they came straight back. I also unplugged the 12v batt for 10 mins but that didn't help either.
Discussion Starter #2
Ok, further research last night and I have a cunning plan...
1. Test the coolant sensor wire to confirm 5v is present. If not it's a broken wire.
2. Borrow the coolant sensor from my other Volt (handy to have a spare). Reset the codes and cross fingers.
3. If step 2. fixes it install the sensor defeat device (24kohm resistor) for permanent fix
4. Repeat permanent fix on other Volt.
5. If all the above fails ring Bellingers.
Much info gleaned from this link...
Ok, further update. There was 5v at the sensor wire, and the unplugged sensor had a resistance of 24kohms. Moving it close to a magnet dropped its resistance to nearly nothing, so it seemed to be ok. Swapping the sensor from my other Volt didn't help either, so I'm at a bit of a loss. I can't find anything wrong! My only thought is a transient fault which latched a code that Torque can't clear. I understand that this is possible and needs a dealer reset. Off to Bellingers it goes!
The coolant sensor will latch 'fail' if you don't completely disconnect the 12V and allow a good time for the system to discharge.
An intermittent connection might have latched it fail, you will need a dealer to clear the code.
Sensor failures are one of those 'things' to fix for good; replace it with a dummy sensor/resistor. It's a useless component.
Thanks Donald. I did try disconnecting the 12v, but only for 5 mins. I'll give it an hour this time.
I already have some 24kohm resistors on order to permanently fix it.
No, I mean it latches if the fault/disconnection occurs while 12V is live, and then NEVER goes off until you see a dealer.
It all dates back to some crash test the NTSA did, and the Volt that was crashed caught fire a few weeks later when someone tried to activate it, or something like that. The coolant had disgorged itself into the battery cavity and there was a 'thermal event'. So GM was forced to retrospectively include a level sensor in the battery level. The early models repurposed an unused HVAC wire, so that was unreliable, and then the sensor itself is not reliable either.
So the fix is to lock in a dummy resistor, making sure to power down the system first. The fault flags and latches, and that's that.
I am not saying that is what you have for sure [and/or your 'original' problem], but if you have disconnected the coolant sensor line while 12V was connected then you would have triggered this.
Quick update. I swapped over the coolant sensor from my other (2013) Volt before I saw Donald's last post. It didn't fix the issue on the 2012 car. However reinstalling the 2013 sensor back in the 2013 car made the same error appear! Doh! It turns out (as Donald points out above) that the sensor is live all the time. Unplugging it even if the car is turned off is enough to trigger the fault and disable charging. I should have disconnected the 12v first. Lesson learned!
I thought I'd have a go at clearing the code; anything to save two 80 mile 'round trips to Bellingers. Amazingly it worked! Phew!
So turning back to the 2012 Volt. The 24kohm resistors turned up and I wired one in place of the sensor. Cleared the codes but they came straight back. Boo!
So either the 2013 Volt is more 'fixable', in that clearing the code allows the car to be charged again, or the fault isn't with the coolant sensor at all. An issue with the charging port gives the same error. I did remove the charging port and put a heat gun on it but the error still stayed on after putting it back together.
Time to admit defeat and book it in with Bellingers.
Twin Amperas
Hi Roger,
Sadly sounds like you might be stuck with a visit to Bellingers - we take both our Amperas there and are very happy with their service but it's a bit of a trek for us...
However there might be one last option worthy of a look - Autel market a 'DIY' version of their MK808 Pro scanner (£650) called the AP200 at £60 - you have to designate one make for it to work with when you set it up, which it is locked to for life, although you can add a second make for a year at $22...
I also have Torque Pro and a generic OBD scanner, and there is no comparison between that and the AP200 - Torque Pro only does engine ECU diagnostics and code resetting, whereas the AP200 does all the cars systems and can do some 'dealer level' functions like coding keys, new injectors etc...can't promise it will sort your issue but it just might help, and is well worth having for all the extra functionality over the generic OBD stuff...for £60 it might be worth considering...
Have a look on Amazon for Autel AP200 Bluetooth OBD2 Scanner Code Reader with Full Systems Diagnoses, AutoVIN, Oil/EPB/BMS/SAS/TPMS/DPF Resets IMMO Service for Family DIYers (DIY Version of MK808)
Good luck and I hope you get it sorted without too much hassle...
Cheers, Nathan
I think they built in some sort of 'maybe once' kind of trigger. Really can't say, but I know that one of the reasons this is a Big Deal is because that 'made up' repurposed HVAC line on the early Volts I mentioned routinely fails and our US colleagues get rightly p!ssed about it. I believe that all the Volts and Amperas that made it here were post-fix on this, but the latched lock-out is a feature. Maybe you get one start-up with the sensor error, and the second latches.
Discussion Starter #10
Hi all.
Just to let you all know how I got on with this issue for your future reference.
After much online research I ended up buying a vcx nano dongle (£75) and used it to reprogramme the HPCM2 module just like the dealer would. This turned out to be remarkably easy. You can get a 2 hour subscription to the acdelco programming website for about £40. Plus I have now have the dongle for future use.
Once the module had been reprogrammed and the error codes cleared I could charge the car again. Hooray!
Unfortunately my joy only lasted for 2 hours, as the car stopped charging and the error came back. Boo!
Further checks showed the coolant sensor wiring was dodgy, although I did get voltage from it when I checked it prior to reprogramming. The wiring runs very close to the exhaust and is prone to degradation. So I unwrapped the loom at the top of the engine, cut the two sensor wires and soldered in a 24kohm resistor between them before wrapping it back up. I then managed to clear the fault codes with just my phone and standard ODB dongle; a further reprogramme wasn't necessary; presumably because I hadn't started the car to latch the fault.
And it works! Fully charged it from the sunshine today and just drove it 15 miles on pure 'leccy.
All for the sake of a 10p resistor! Hopefully it will now stay fixed!
Hi all.
Any chance you could give a bit of a walkthrough how you cleared this code?
I have the same issue with the faulty coolant level sensor, have ordered the sensor defeat kit from the US but looking at a 3 hour drive to the nearest vauxhall dealership to get the latched code removed and the sensor replaced, to then have to drive home and fit the sensor defeat. Much appreciated.
Discussion Starter #12
Sure.
1. Fix the issue, be it sensor or wiring. A 24kohm resistor (£1 for ten on eBay) bypassing the dodgy sensor and wiring has sorted it for me.
2. Purchase a vcx nano (GM version) from Amazon/eBay. Approx £75.
3. Plug vcx into OBD port on car and laptop USB port. Power up car in service mode (hold power button for 10 seconds)
4. Go to the AC Delco website ACDelco TDS
5. Purchase a 2 hour subscription (approx £40). Download and install the required reprogramming software that pops up.
6. Choose module reprogramming and select the HPCM2 module. Reprogramming takes about 10 mins.
7. Select yes to the request to clear the outstanding fault codes.
There are several videos on YouTube that that take you through this in more detail, such as this one from AC Delco themselves...
Anyone know roughly how much a dealer is likely to charge to fix this?
Mine threw up the same error a week ago but I wouldn't feel confident enough to try the fix suggested so will need dealer input.
Sent from my SM-G965F using Tapatalk
Discussion Starter #14
A dealer would only be allowed to fix it using the official parts and methods, so if it is definitely the sensor or wiring they would need to order and replace those parts, then reflash the HPCM2 module.
My guess (and it's only a guess) would be a couple of hundred quid.
The first thing to do is check the battery coolant level first. It might really be low!
Cheers mate, a couple of hundred I can deal with!
It's currently in for accident repair so will check the coolant level when it comes back. It had a service 5 days ago though so I'd hope they'd have checked the level...
Sure.
Hey Roger, many thanks for this. I've just received my defeat plug for the sensor from the US and haven't been able to clear the errors using any apps and either of two obd scanners.
I've actually had the car to a dealer now also who after four hours with the car, didn't charge me as their Ampera technician apparently was not working that day - after I drove there on purpose three weeks after making a booking and taking a day off work.
Do you still have use for the vcx nano or would you consider selling or tent it?
That's pretty much what happened to me. Arranged a service at a dealer, said what the problem was and they even checked that a proper technician would be there to diagnose.
Turned out they were never qualified to do anything with the car, and wouldn't even read the error code for me, although only told me that when I picked it up after the regular service.
Beyond angry....
Glad you got it sorted.
Why Bellingers? Are they only few dealer who could sort Ampera out? So far to go if you not local to that town and the inconvenience.
Is there a list of qualified dealer to repair Ampera?
Don't think there's a list, if there was I'd at least hope the dealerships would know it!
Don't trust the Vauxhall website! Last year I tried to use it to see if the local Vauxhall dealer did Ampera servicing - the website said yes. However I called the next closest dealer (Bellingers) who said that was incorrect. I suggest you phone the dealer and speak to them.
1 - 20 of 66 Posts
