Opened up the NS headlight and guess what I found?
A single Phillips HIR2 /2012 bulb. Oh but that's a low beam 55w bulb right? So where's the high beam bulb?...... There isn't one, just a single low beam bulb.
So, how does high beam work without a bulb? Those who don't want to be on a downer quit reading now.
The headlight is angled up, sort of where a high beam should be but there is a what looks like a gate blocking just less than half the light. Select high beam and the gate moves and you get all the light. If you use a white wall and park about 1m away then you can see for yourself. I did take some pics of the inner working of the lamp but the 'choose file' is greyed out.
So low beam is like driving on high beams, with a low beam bulb and tape over the top half of the headlight. I need a box of doughnuts right now.
