1 - 4 of 4 Posts
Hi
I am looking at buying one of these from here as I have a spare type 2 mennekes tail.
Has anyone else used/built one of these?
It claims up to 60Amps but I'm guessing this is assuming 120v? Would this work on a 32amp 240v circuit in the UK?
I have built one. It works fine on 240V UK. I am using a box with a type 2 socket. The only tricky thing in the UK is the earthing if the charger is outside. If possible I would suggest using it in a garage as you don't need to worry about it then.
1 - 4 of 4 Posts
