Interesting!I had an update this morning. The update suggested I did not drive the car during the update but did not give me any other information. I connected the car to wifi and started the update but nothing much has happened. I'll check later on this morning.
Let’s hope it’s not a bug! Surprised we’ve heard nothing about any impending OTA update.There was nothing in notification but a service menu appeared with an option to start the upgrade. I pressed update but nothing much happened. I should have taken a picture![]()
I hope I haven't started a "wild goose chase" discussion thread on the OTA ...... hopefully Battery Life (Chris?) is correct and that it is imminent. For me the ID 3 overall is an excellent car but is not without its shortcomings - no car is perfect. On the software side here are some potential changes I think that might be significant improvements........I believe the 1st OTA update for the VW ID3 is coming very soon - per Battery Life. Anyone know any more details re: timing and possible content?
On no. 4 agree with you on safety grounds. Not an issue for me really but heard others complaining about it. I suppose it depends on the roads you normally travel onI don’t think you’ll see number 4, it’s an NCAP requirement that it’s not easily disabled now.
Number 2 might happen once VW have some more data around long term battery health etc.
You forgot another...wing mirror adjustment switch to remember where it last was so you don't have to select L every journey to get kerb mirror dip.I hope I haven't started a "wild goose chase" discussion thread on the OTA ...... hopefully Battery Life (Chris?) is correct and that it is imminent. For me the ID 3 overall is an excellent car but is not without its shortcomings - no car is perfect. On the software side here are some potential changes I think that might be significant improvements........
1. Increase Regen further (I think regen was increased as part of 2.1 update - did others notice this?)
2. Reduce kWh taken from battery as part of BMS heating of battery in temps < 8 degrees C
3. Software tweaks to speed up response times of info system at start up and during use
4. Short cut buttons for disabling lane assist/others?
Yes, ex e-Golf owned here as well, I’m sure they’ll be looking at the battery heating thing as a few reviewers have mentioned it. They still might do nothing though.On no. 4 agree with you on safety grounds. Not an issue for me really but heard others complaining about it. I suppose it depends on the roads you normally travel on
On no. 2 - again agreed. VW shouldn't change the BMS settings if they really think it will cause battery health problems. I suppose I'm challenging how they set up the parameters in the 1st place ( at less than 8deg use x kWh to heat). Prior to the ID 3 I had the e golf ....... which has no battery heating - yet is guaranteed by VW for 8 years to 70% SOH.
Thing is, if they did that, I’d need to unselect it when I selected reverse but didn’t want the mirror dip, like reversing out of a parking space.You forgot another...wing mirror adjustment switch to remember where it last was so you don't have to select L every journey to get kerb mirror dip.
9 times out of 10, when I reverse I either want the dip, or don't mind the dip. When reversing out of a space I'm far more reliant on my rear parking sensors than my passenger wing mirror. It's my only real inconvenience with the car, and it's a small one I'll admit (the wife's moaning about the issue when she's driving is worse than my experience of the issue when I'm driving).Thing is, if they did that, I’d need to unselect it when I selected reverse but didn’t want the mirror dip, like reversing out of a parking space.
It’s 6 of one and half a dozen of the other for me!
Glad to hear about Regen - that it just wasn't my imagination.I drive not only with all the assists but on Travel Assist nearly all the time, I've no idea what people's beef is with the assist, but I'm not opening that can of worms, it's just modern cars in general which err on the side of false positives, for obvious reasons. It won't change much, it's an NCAP thing.
Regen is much better in 2.1. I don't have a problem with that either, I think people need to get with the philosophy of the car which is that it coasts, unless it detects an area you need to slow down. And B mode is fairly punchy, but not aggressive. I think it's a design choice. You're still recovering the same amount of energy for the amount you slow down. I don't find I use brakes much especially with Travel Assist/ACC doing the work for me coming up to lights etc. Different cars have different approaches. It's not much different to how different cars have different gearbox gearing traditionally, really.
The NUMBER ONE thing I want is driver profiles. It is daft to have electric seats and electric mirrors and they don't switch between drivers.
