1 - 3 of 3 Posts
I have a departure time set to charge and heat vehicle. When I connect "granny charger" and press the top button at charging flap to override the departure time, the button lights up and charging begins.
I have noticed over the last few weeks, on various days intermittently the car will sometimes charge to 100% or other days only to 60% as per the minimum charge level when a departure time is set, even though I have pressed button to override departure.
I have a 2018 advance with granny charger used once a day at work. Zappi at home. Can't say I've noticed the same issue with Zappi.
Anyone else had this issue occur?
Thanks in advance.
I've not had this issue occur. It always works fine with my car.
Have you tried with a Type2 cable? Perhaps the granny is overheating/detecting a fault and this is causing the car to stop momentarily, but if it is on a scheduled charge it may continue automatically.
It always reaches the lower charge limit set when departure time is set.
If it was stopping before this I would think it could be overheating as you suggest.
1 - 3 of 3 Posts
