Thanks, that's what I tried, do you need to be moving when you do this?One press turns it off (led on),press it when your hearing the initial sound and hold down it should cycle through options.
Changing the tone should be saved for your next drive. But if you silence it, it will switch back on the next time you start the car after more than 10 minutes parked and locked up.Hi portmoon. If you change the selection, does the car remember this next time you use it? Or does it reset to the default tone?
