Hi all.
I read that the above appears to be a common issue with the Kona and Ioniq, whereby the 12V battery discharges (resulting in a flat battery). T
Couple of queries:
a) Does the HV battery trickle charge the 12V battery (similar to what happens in the 40kW LEAF)?
b) Does turning off the aux battery saving have any affect?
c) Several (?) people have mentioned about water ingest in doors causing a short circuit. Is this a systematic quality issue with both models (if so, surely a recall is required?)
d) Others have mentioned that it is down to the quality of the 12V battery used.
I am assuming that if you are constantly using the car, then the probability of having a completely discharged 12V battery is greatly reduced?
Thoughts?
Kieren
Couple of queries:
Thoughts?
Kieren
