1 - 7 of 7 Posts
Does anyone know where on a Pod Point Solo the keylock is located if it is ordered as an optional extra? There’s a picture on the Pod Point website but I can’t quite tell where it's installed and it looks like it is at the top. On another example I saw it on the unused flat cable entry area on the right. Or is it that key switch isn’t factory preinstalled and can be installed on any of the flat unused cable entry areas by the installer?
Mine is on the left hand side, the cables go in and out at the bottom. Will take a photo if it stops raining :)
Reactions: aam
Here you go.
128173
Reactions: aam
Thank you. So it looks like it can be fitted to any of the unused flat cable entry locations around the edge, whichever is most convenient.
Where does it connect to on the circuitboard?
Just a 2-pin jumper location on the bottom left of the board. Varies a bit depending on which version of the PCB but generally around the same area if the pins are there.
1 - 7 of 7 Posts
