Absolutely agree with this - the office ask a lot of questions and find problems where there are none. Was told I needed to pay for a new small CU, but the installer put in a voltage regulator(?) instead of a earth rod and I didn't get charged.Sample size of one, but BP Chargemaster did a great job with my home charger. They installed in back in March just as lockdown kicked in and I didn't use it until August when my car (Zoe) arrived. It worked first time and has given zero issues. I like being able to sign in and see how much energy has been delivered by each charging session. Their office was a bit of a pain to deal with, but the electrician was top notch and did a good job on my slightly tricky cable run.
Hey @Hotlush , I think I remember your thread from the Zoe board (we were having our problems about the same time). You fixed yours in the end by cleaning the contacts on the Zoe's charger?Might not be a BP/Chargemaster specific issue but working out what was wrong with my setup consisted of replacing the unit, shrugging and stating the car is at fault when that didn't work.
Considering they are the "official" partner of Renault you'd think they'd have some basic equipment/facilities to be able to test both sides of the setup on-site, rather than sending you to the dealer who just notes it works on their charger.
Thats right.Hey @Hotlush , I think I remember your thread from the Zoe board (we were having our problems about the same time). You fixed yours in the end by cleaning the contacts on the Zoe's charger?
Hi Harry, I had my BP Chargemaster installed on Wednesday and getting my Zoe on Monday.Sample size of one, but BP Chargemaster did a great job with my home charger. They installed in back in March just as lockdown kicked in and I didn't use it until August when my car (Zoe) arrived. It worked first time and has given zero issues. I like being able to sign in and see how much energy has been delivered by each charging session. Their office was a bit of a pain to deal with, but the electrician was top notch and did a good job on my slightly tricky cable run.
I use a laptop rather than a phone app to access the data, don't know if that makes a difference. Here's the link I use:Hi Harry, I had my BP Chargemaster installed on Wednesday and getting my Zoe on Monday.
Where do you sign in / register to see how much energy has been delivered?
I have installed the app on my iPhone which asks me to log in, but I cannot find anywhere to register before logging in.
Hey Andy,I don’t know about PodPoint but chargemaster seem to be installing without an Earth Rod nowadays which makes life a bit easier.
As above, they will send you an email invitingyou to register/login.Hi Harry, I had my BP Chargemaster installed on Wednesday and getting my Zoe on Monday.
it is for a Zoe - apparently it uses a “pme device” and uses the ground of the grid which is much more reliable than a ground rod. In practical terms a new consumer unit with magic inside it is fitted between the meter box and the charger bypassing the existing CU.Hey Andy,
Chargemaster knew that our Zoe needs a good earth and certainly did install an earth rod for us. I guess if your car is less fussy than a Zoe(?) then maybe you didn't need one?
Interesting! and good to know. Hopefully all will be well when your car arrives. We didn't use ours for 5 months and it worked first time, so hopefully yours will be the sameit is for a Zoe - apparently it uses a “pme device” and uses the ground of the grid which is much more reliable than a ground rod. In practical terms a new consumer unit with magic inside it is fitted between the meter box and the charger bypassing the existing CU.
I don’t know if this is suitable for all installations but apparently is a fairly recent change or interpretation of the regs?
I also don’t know if it works yet as I ain’t got the car yet, but people on the RZOC Facebook group say theirs works fine.
