1 - 11 of 11 Posts
Mitsubishi Outlander PHEV (2015)
Hi all,
Have my Outlander. Loving it so far and pleasantly surprised at the amount you can ask and it'll stay in EV mode. My worry of the dip in my commute is no bother for EV.
However, I have a question rather the pre-heating. I managed to connect to the app and did a heating test last night to which the heating came on. Great.
I then set a schedule for pre-heating at 7:40am. It then seemed to successfully 'send' the schedule which I am presuming went into the car's memory.
However, when I came to the car this morning it was not heating at all. Does the phone need to be near it for it to work? I presumed when connected and you 'send' the schedule it then logged in the car's memory.
Am I missing something?
Also, what temperature does the car try and heat up to? There's no customisation regarding this. It also only expels heat via the windscreen vents.
2021 Citroën ë-C4 Shine Plus
Setting the timer schedule is just the first step. Once set, make sure it is active by setting the slider to 'on'. The 'send' operation then stores the schedule in the car's memory.
You then need to turn on scheduled operation by touching the 'set' button on the home screen, which should turn blue to indicate that scheduling is now turned on. Similarly, you can touch the 'set' button again to turn scheduling back off.
There is no way to set the temperature, instead you have to rely on the time the heater runs for (10,20, or 30 minutes).
A few of us have an issue that the car won't wake for preconditioning if charging has finished as the car appears to "go to sleep". The only way round it that I have found is to make sure the car is charging when the preconditioning starts, either by guessing the end time of the charge and setting the preconditioning to start during that window, or having it fully charged already and then having a charge timer start at the same time as the preconditioning.
Note that the electric heater takes up to 4kW, so neither the granny cable nor a wall charger will be able to keep up, especially if the charge rate is low because the battery is full. So you may want to leave it charging after the preconditioning has finished, though obviously the car will be cooling down. It's a trade off between a full battery and a warm car
Mitsubishi Outlander PHEV Design 2.4
At the start my battery was full, I set the remote to defrost for 20 minutes, I charged up over night using my PodPoint EV, app recorded 1.7kW to charge up to full.
2019 Kona 65Kw 2017 Outlander phev gx4hs
On the app you can temporarily switch off scheduled charging and then switch the heater on and the car is warm from the comfort of your toasty warm house :cool:
1 - 11 of 11 Posts
