1 - 20 of 22 Posts
· Registered
Finished installing Predictive Cruise Control on my GTE.
Things I needed for the upgrade:
Camera:3Q0980654H
VAS6430 calibration target(If you upgrade the camera)
ABS Pump:5Q0614517BL
Radar:5Q0907572
MIB2.5(Optional)
Things I had upgraded previously:
Virtual Cockpit
ECU
Gateway
Step 0: ABS pump upgrade
This is kind of a prerequisite to the pACC. Not everyone would need to do that I had to upgrade my ABS pump because it didn't support the new version of stop and go ACC. Got it for cheap and coded it based on the old ABS pump and some help. (details below)
Step 1:Install camera
My car did have an older version of the lane assist camera (5Q0 camera) and I need the 3Q0 camera. My challenge was to replace the old smaller camera with the new bigger unit (See picture 1) without replacing the windshield. Both have different mount points, connector positions, camera lens size and angle. Also the shape is completely different. Not only that, the angle of camera lens are also different. This is accounted for later.
138383
(image from golfmk7.com)
Plan 1(failed) was to mount the new camera lens in the old body with a 3D printed spacer (new camera lens is smaller than the old one) and run a cable to the new module and hide the module in the roof trim. But the signal is too weak to travel that distance. Kept giving errors saying camera not installed correctly. Older cameras were built better I guess. that's why this method worked for 5Q0 cameras (mqb.pl)
138385
Plan 2(success) was to keep the top of the old mount so that the lens mounts perfectly in the same location and the anchor points remain the same but fit everything from the lower half of the new module. This way, I don't need any additional cables and everything plugs straight in. After a lot of cutting and grinding of the old camera's aluminium casing. I managed to fit it in. I had redesigned the 3D printed spacer to account for the difference in angle between the 2 camera modules as well. I added extra insulating and heat resistance tape to prevent heat and short circuits in the frankenstein I created. Secured the PCB to the bottom plate with zip ties as there were no screw holes to secure it. Final modification was to cut the little black plastic tab that was in the way. This turned out to be a much better solution.
138388
138389
138393
138391
Step 2: Calibration
After I was happy with the mounting solution for the new camera. It's time to calibrate the new camera. You can get someone to do this professionally but I was on a budget and I trusted the VW dealer enough to know that they would charge me full price even if they cant calibrate the camera.
So, I downloaded and printed the VAS6430 and followed the various guides available online. But what worked at the end trial and error based on educated guess (Camera is mounted at a different height on the mk7.5s). One thing to note is that calibration process on ODIS for this camera is internally different from the older camera. When using ODIS to calibrate, please manually select a mk7.5 golf.
138392
(image from mqb.pl)
Step 3: Radar
The most easiest step. Remove your old radar and install the new radar.
Rest of the work is proprietary information owned by Henno. He will flash the right firmware and activated the right SWaP codes for you remotely.
138394
Step 4: MIB2.5 upgrade (optional)
I just went for it anyway, not really a requirement for this. Just liked the look.
ALL DONE!
Now if I use the satnav, it can predict the changes in speed limit and automatically adjust the cruise control. Not only that, it will also slow down for sharp bends, roundabouts and junctions.
If you don't use the satnav, it still works but struggles to realise roundabout and junctions.
138395
(stock image)
To adjust the speed limit, it uses both, the satnav data as well traffic sign recognition (camera) to adjust the speed limit.
Additional feature includes, wrong side overtaking prevention: meaning, if you are in lane 2 and the cars in lane 3 are going slower than your lane. The car will not accelerate past them.
138396
(stock image)
PS. different people helped me different things for the remote coding. I will be happy to provide their contact details.
· Registered
Camera:3Q0980654H
Radar:5Q0907572
MIB2.5(Optional)
Virtual Cockpit
ECU
Gateway
View attachment 138383 (image from golfmk7.com)
View attachment 138388 View attachment 138389 View attachment 138393 View attachment 138391
Step 2: Calibration
View attachment 138392 (image from mqb.pl)
Step 3: Radar
ALL DONE!
View attachment 138395 (stock image)
View attachment 138396 (stock image)
I have done as per you but I receive error says 'Predictive cruise control is out of service in this country' . I am from Turkey. Has anyone receive such error ? Any idea for solution? Please help
139334
· Registered
I have done as per you but I receive error says 'Predictive cruise control is out of service in this country' . I am from Turkey. Has anyone receive such error ? Any idea for solution? Please help View attachment 139334
I had something similar. Just had to update the maps and upload the right dataset on the MIB2.5 unit
· Registered
Fascinating stuff.
Don't wish to rain on your parade but the immediate issue I see is - how do your insurers feel about this mod? I'd imagine the snowflakes running the car insurance scam - sorry, businesses - these days would last be seen running away as fast as they can!
· Registered
Discussion Starter · #9 ·
Fascinating stuff.
I spoke with them when I installed my MIB2.5 and Virtual cockpit. They said because they are OEM parts and available as optional extras from the manufacturer it is not classed as modifications. Its technically the same parts available for newer Golfs, I just retrofitted them on an older Golf. But every company varies.
· Registered
Good work with your insurers - last time I tangled with mine for a different car it was painful.
For technical interest I'm going to dig into this a little more, thanks for your write up.
· Registered
Wow this could get interesting, think a certain dealer is about to get a cancelled order... I want to know if my car has the adaptive AND predictive cruise control, by which I mean that when entering a speed limited area, say for example 30 MPH, if I am doing more than the posted limit the car will automatically adapt its speed to be within the required speed limit.
My Car is going to be a VW Golf MK8 Estate Style 150 DSG, I do have the vin number and wonder if some kind person can find out if the car will do what I am asking of it. The car also allegedly is fitted with Dynamic Road sign assist TravelAssist and Side assist Lane change assist and emergency assist. Thats a lot of assistance, but really speaking the assistance i need right now is from someone who can spec check my vin, but i'm not going to send it until i know if it is needed or not. The car is not yet registered, and I still have time to cancel it if the dealer has misinformed me, and change it for something that does what I am asking for..
Can any one help Please??
· Registered
By the way I do know that i am replying to an EV FORUM but am assuming commonality of components across the VW range.
· Registered
Discussion Starter · #13 ·
if you got predictive cruise control, you already have adaptive cruise control. if you are about to enter a 30mph zone, it will use the sat nav data to start slowing you down before the zone arrives. If the doesn't know its a 30 zone, then it will reduce the speed after the car sees the 30 sign.
With all the assists you have available on the car ,you are fully assisted. You can run your VIN on Erwin website to obtain the Vehicle Information. That will give you all the information you need about the car. But it does cost 7EUR for an hour of use.
· Registered
Hi,
This is quite an informative and encouraging write-up!
I would like to explore the option of enabling pACC in my car (VW Passat R-line). It has most of the components already installed and the part numbers are also similar.
I can share with you the autoscan; please let me know if its possible to enable pACC and how I can do it.
Any assistance is highly welcome.
many thanks,
Nitin[/QUOTE]
· Registered
Discussion Starter · #15 ·
Hi,
many thanks,
Nitin
[/QUOTE]
Thanks. Feel free to send it to me
· Registered
Hi,
Here's the autoscan:
Wednesday,09,September,2020,19:00:44:34260
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ3CZKE054334 License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 4B 52 5F 6C
A5 BB BC CA CF D6 D7
VIN: WVWZZZ3CZKE054334 Mileage: 17866km-11101miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CJSA) Labels:. 06K-907-425-V1.clb
Part No SW: 3G0 906 264 HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0004
Revision: --H13---
Coding: 092500322464050B3000
Shop #: WSC 05311 115 00311
ASAM Dataset: EV_ECM18TFS0203G0906264 001007
ROD: EV_ECM18TFS0203G0906264_VW48.rod
VCID: 6597B067C5E99B63C15-8030
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 043 H HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1601
Revision: 00005008 Serial number: CU501811136031
Coding: 0014
Shop #: WSC 05311 115 00086
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW31.rod
VCID: 3C21350316E3FAAB4EB-8068
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DH HW: 5Q0 614 517 AH
Component: ESC H62 0754
Revision: 00000000 Serial number: 63258000001330
Coding: 0EEC928F34252370477A060360C74970492CC4E2600692753842F038C2A9420B00000012121212B835351919323200
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 7AADF31B5C57049B1C7-802E
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0499916047
Coding: 1F20000723
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB.rod
VCID: 43D34EFF6B1D85530F1-8016
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 DP HW: 5G0 907 044 DP
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 1112001420010000111510401210182A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 78A9E913625B168B6A3-802C
Fresh Air Blower Front:
Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
Air quality sensor:
Relative humidity sensor in fresh air intake duct:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 086 BQ HW: 5Q0 937 086 BQ
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: 8658081118000S
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019.rod
VCID: 0A4DA3DB0CB7141B0C7-805E
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 181104 043 0607
Serial number: 181115102536
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: S7Y18M11D29H15M50S54
Coding: 00A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 25 09 2018 10000464
Relative Air Humidity Interior Sender:
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 521 AS HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100241120180C301643
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 F HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0453
Serial number: 000308417618311
Coding: 0371167851
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 53F37EBF9B7D15D3BF1-8006
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H05 0196
Coding: 320467D359FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3537202735C92BE3B15-8060
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 BJ HW: 3Q0 959 655 BJ
Component: Airbag VW21 006 0712
Revision: -------- Serial number: 003W5PN9QTH/
Coding: 98FCC0C0000000005C540000008800000065
Shop #: WSC 05311 000 08193
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 074B9AEF1FA56973139-8052
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 454 000 611 18
Component: SideSensor_Df 008 0887
Serial number: 35700000000162717231
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 454 000 611 18
Component: SideSensor_Pf 008 0887
Serial number: 35800000000B5271723B
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 454 800 810 18
Component: SideSensor_Dr 301 0148
Serial number: 35100F6C57A16000000S
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 454 801 211 18
Component: SideSensor_Pr 301 0148
Serial number: 35200E660D916000000M
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 454 802 510 18
Component: FrontSensor_D 304 0149
Serial number: 35500E5619C16000000O
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 3G0 920 791 D HW: 3G0 920 791 D
Component: KOMBI 403 4191
Coding: 27A501186F8C000801887B0B1001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 2A0D035BEC77741B2C7-807E
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 29111810804595
Coding: 030300347F085900FB00025A1C0F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013025
ROD: EV_GatewNF_VW37.rod
VCID: 6E85CF4B101F583BB0F-803A
Alternator:
Component: 0-00-03-00-04
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0052
Serial number: 29180002805690098475
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75886002001811091A89
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 1311201800010362
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000349925013
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 33331E3F3BBD35D39F1-8066
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 D HW: 3Q0 959 760 D
Component: Sitzmemory H06 0024
Serial number: Y0006RKR13119
Coding: 001400020000050081C280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide.rod
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 G HW: 3Q0 907 566
Component: MRR1Rear H23 0530
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
ROD: EV_RearRadarS1BoschVW48X.rod
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RKG05581
Coding: 003F1B20D201020000000000
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 44D14DE36E13826B36B-8010
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 93170000
Shop #: WSC 00015 115 00311
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 23111810521586
Coding: 000000060900034E01004F05020000040000000000000000000000000000
Shop #: WSC 05311 123 08193
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW41.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo links H02 0003
Coding: E02400
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo rechts H02 0003
Coding: E02400
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RKG17817
Coding: 003F1120DE01020000000000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
ROD: EV_DCU2PasseSideMAXHKLO.rod
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 045 C HW: 5NA 035 045
Component: MU-H-N-RW H55 1161
Serial number: A849K0JS036922
Coding: 02840108FF00000051510001000808001F0106E601200402DF
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
VCID: 3829291322DBD68BAA3-806C
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H52 9130
Serial number: VWZ6ZJV3280358
Data medium:
Subsystem 2 - Part No SW: V03 959 806 NC HW: -----------
Component: ROW 2020/2021 --- 0088
Serial number: --------------------
Compact Disc Database:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 4013
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0184010162002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 392F2C1719D1CF8355D-806C
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 20081815P12294
Coding: 000408010000010100022346C150A90094000E300040
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_001_VW36.rod
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS003 0187
Serial number: YE007RKD22815
Coding: 000E11200101020000000000
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001010
ROD: EV_DCU2RearDriveMAXHKLO.rod
VCID: 4EC56FCBB05F783B90F-801A
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS003 0187
Serial number: YE007RKD22811
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001010
ROD: EV_DCU2RearPasseMAXHKLO.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 K HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 508000748101
ASAM Dataset: EV_SunRoofCONTIAU736 006008
ROD: EV_SunRoofCONTIAU736_006.rod
VCID: 3E253F0B00FFE8BB60F-806A
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 G HW: 3Q0 907 590
Revision: --------
Coding: 44C002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
ROD: EV_RearRadarS2BoschVW48X.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 1675C7AB480FC0FB98F-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----------(Elapsed Time: 02:11, VBatt start/end: 12.6V/12.6V)-----------
· Registered
Wow, first congrats for your job. So I have a doubt about what measure of flat cable that you used in the first test that you didn’t have success?
thanks
Ricardo Soares
1 - 20 of 22 Posts
