Hi Guys
I plugged in my ODB11 are tried to look at the battery health.
I keep getting function not available.
Below is a screen shot and output of faults found.
Anyone know what I could try.
I dont have the pro version could this be why??
Mark
OBDeleven data log
Date: 2020-02-14 19:46
VIN: WVWZxxxxxxxxx
Car: Volkswagen e-Golf
Year: 2017
Body type: 5-dr hatchback
Engine: EAZA 100 kW (136 HP) - l
Mileage: 23028 KM
01 Engine Control Module 1
System description: E-Vehicle
Software number: 0EA906016E
Software version: 4219
Hardware number: 0EA907309A
Hardware version: H24
ODX name: EV_VCU00XXX0110EA906016E
ODX version: 004007
Long coding: 000D0012006404002008
Trouble codes:
U011000 - Lost Communication With Drive Motor Control Module "A"
Intermittent
P060C00 - Internal Control Module Main Processor Performance
Intermittent
P091900 - Gear Shift Position Control Error
Intermittent
03 Brakes 1
System description: ESC
Software number: 5Q0614517BL
Software version: 0855
Hardware number: 5Q0614517AH
Hardware version: H62
Serial number: 60617000000817
ODX name: EV_Brake1UDSContiMK100OMG
ODX version: 003019
Long coding: 01FA80A12C25216D477F060341CB2980013484E26082943338915078C26203
Trouble codes:
C101AF1 - Left front ABS wheel speed sensor Magnetic field too low
Intermittent
Date: 2019-12-21 16:14:46
Mileage: 22160 km
Priority: 4
Malfunction frequency counter: 1
Unlearning counter: 255
Extended Freeze Frames: 0E07001823000000AC000000F80100005020100101001000
Intermittent
Date: 2019-12-21 16:24:14
Mileage: 22160 km
Priority: 4
Extended Freeze Frames: 0E07001823000000A9000000040100005220300101001000
U112300 - Databus error value received
Intermittent
C102D00 - Tire pressure warning
Intermittent
C114602 - Tire pressure monitoring display Signal error
Intermittent
C100C07 - Electro-mechanical parking brake button mechanical malfunction
Intermittent
08 Air Conditioning
System description: Climatronic
Software number: 5GE907044AN
Software version: 1702
Hardware number: 5GE907044AN
Hardware version: H04
ODX name: EV_ACClimaBHBVW37X
ODX version: 006145
Long coding: 0012220020011001050500020010102A
Subsystems:
System description: J848 HV-PTC
Software version: 0208
Hardware version: H09
Serial number: LR170693003810000104
Trouble codes:
No trouble codes found
09 Central Electrics
System description: BCM MQBAB M+
Software number: 5Q0937084CF
Software version: 0236
Hardware number: 5Q0937084CF
Hardware version: H34
Serial number: 02001707900018
ODX name: EV_BCMMQB
ODX version: 017001
Long coding: 000000000000000000000000000000000000000000000000000000000000
Subsystems:
System description: WWS 170223
Software version: 0551
Hardware version: 042
Serial number: 170309064403
Long coding: 0E4DDD
System description: RLHS
Software version: 0105
Serial number: S5Y17M03D22H18M41S47
Long coding: 00A8DD
Trouble codes:
13 Adaptive Cruise Control
System description: ACC BOSCH MQB
Software number: 5Q0907572H
Software version: 0620
Hardware number: 5Q0907572H
Hardware version: H10
ODX name: EV_ACCBOSCHVW416
ODX version: 002005
Long coding: 7D0067C159FFC728949C810580400600000000000000000000
Trouble codes:
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655S
Software version: 0870
Hardware number: 5Q0959655S
Hardware version: 010
Serial number: 003MFR02V1M.
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002138
Long coding: 98CCC000002000005C0000CF00C800000065
Trouble codes:
16 Steering Column Electronics
System description: Lenks. Modul
Software number: 5Q0953507GK
Software version: 0140
Hardware number: 5Q0953549E
Hardware version: 003
Serial number: 18031704400657
ODX name: EV_SMLSKLOMQB
ODX version: 020002
Long coding: 0C10
Trouble codes:
17 Dash Board
System description: KOMBI
Software number: 5G1920795
Software version: 2170
Hardware number: 5G1920795
Hardware version: 409
ODX name: EV_DashBoardVDDMQBAB
ODX version: 009052
Long coding: 272470086F840008018869031600082000000000
Trouble codes:
19 Gateway
System description: GW MQB EV
Software number: 3Q0907530D
Software version: 6286
Hardware number: 3Q0907530D
Hardware version: 615
Serial number: 12031710520040
ODX name: EV_GatewNF
ODX version: 013020
Long coding: 0201001706F81000FB001210081D00000001050100070000000300000000
Subsystems:
System description: J367-BDMHella
Software version: 9070
Serial number: 6327713304
Trouble codes:
23 Brake Boost
System description: EBKV
Software number: 5QE909059E
Software version: 0200
Hardware number: 5QE909059B
Hardware version: H14
Serial number: 085430011232
ODX name: EV_BrakeBoostBoschMQBOMG
ODX version: 004001
Long coding: 06720100321900010002000500
Trouble codes:
U111300 - Function limitation due to received malfunction value
Intermittent
42 Door Electronics Driver Side
System description: TSG FS
Software number: 5Q0959593E
Software version: 0041
Hardware number: 5Q0959593B
Hardware version: 020
Serial number: 060317EC404815
ODX name: EV_DCUDriveSideEWMAXKLO
ODX version: 006003
Long coding: 00310320D001048000001000
Subsystems:
System description: FOND_FHSG_DRV
Software version: 0005
Hardware version: 005
Serial number: 00000000000013781784
Long coding: 0D0000
Trouble codes:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 5Q0909144T
Software version: 1072
Hardware number: 5Q0909144R
Hardware version: 129
ODX name: EV_SteerAssisMQB
ODX version: 013144
Long coding: D102
Trouble codes:
4B Multifunction Module
System description: FCM MQB Low
Software number: 3Q0907338
Software version: 0285
Hardware number: 3Q0907338
Hardware version: 001
Serial number: 17031710800253
ODX name: EV_MultiModulContiVW48X
ODX version: 001010
Long coding: 000000070100054E00000101020000000000000000000000000000000000
Trouble codes:
51 Drive Motor Control Module
Trouble codes:
52 Door Electronics Passenger Side
System description: TSG BFS
Software number: 5Q0959592E
Hardware number: 5Q0959592B
Serial number: 070317EC706094
ODX name: EV_DCUPasseSideEWMAXKLO
ODX version: 006003
Long coding: 00310320DE01048000001000
Trouble codes:
5F Information Control Unit 1
System description: MU-H-N-EU
Software number: 5NA035043
Software version: 1077
Hardware number: 5NA035043
Hardware version: H51
Serial number: A848C0HB003441
ODX name: EV_MUHig4CGen2HBAS
ODX version: 001001
Long coding: 02738001FF00000051110001000808001F0105E6012004009E
Trouble codes:
75 Telematics Communication Unit
System description: OCULowMQBLGE
Software number: 5NA035284A
Software version: 0615
Hardware number: 5NA035284A
Hardware version: H13
Serial number: 0
ODX name: EV_OCULowMQBLGE
ODX version: 003042
Long coding: 02737001EA429A0D3BFCBE000045400382E608
Trouble codes:
76 Parking Assistance
System description: PDC 8 Kanal��
Software number: 5QA919294A
Software version: 0038
Hardware number: 5QA919294
Hardware version: H07
Serial number: 00030841861708100086
ODX name: EV_EPHVA18AU3700000
ODX version: 009031
Long coding: 2471051011
Trouble codes:
8C Battery Energy Control Module
System description: K8C
Software number: 5GE915225A
Software version: 0350
Hardware number: 5GE915225A
Serial number: 22021705010012
ODX name: EV_BECM08820215GE915225A
ODX version: 001003
Trouble codes:
A5 Front Sensors Driver Assistance System
System description: MQB_B_MFK
Software number: 3Q0980654G
Software version: 0231
Hardware number: 3Q0980654
Hardware version: H06
Serial number: 20031711P12225
ODX name: EV_MFKBoschMQBB
ODX version: 001001
Long coding: 0003070000000401000223448050490094000E200020
Trouble codes:
BD High Voltage Battery Charge Management
System description: LMSG
Software number: 5QE915022AB
Software version: 1094
Hardware number: 12E915022F
Hardware version: H20
Serial number: 01147071040115
ODX name: EV_HVChargManagVWMQB
ODX version: 003004
Long coding: CA0914040400
Trouble codes:
C6 Battery Charger Control Module
System description: OBC Delta-ES
Software number: 5QE915681B
Software version: 1560
Hardware number: 5QE915681B
Hardware version: H52
ODX name: EV_OBCTwoPhaseDT2VW3707
ODX version: 003009
Trouble codes:
D6 Light Control Left 2
System description: LED1L
Software number: 7P5941591AD
Hardware number: 7P5941591A
ODX name: EV_LED_PLUS_L_KEBODAVW416
ODX version: 001003
Trouble codes:
D7 Light Control Right 2
System description: LED1R
ODX name: EV_LED_PLUS_R_KEBODAVW416
ODX version: 001003
Trouble codes:
Mark
OBDeleven data log
VIN: WVWZxxxxxxxxx
Year: 2017
Mileage: 23028 KM
ODX version: 004007
Trouble codes:
Intermittent
Intermittent
Intermittent
03 Brakes 1
ODX version: 003019
Trouble codes:
Intermittent
Mileage: 22160 km
Priority: 4
Intermittent
Mileage: 22160 km
Priority: 4
Intermittent
Intermittent
Intermittent
Intermittent
08 Air Conditioning
ODX version: 006145
Subsystems:
Trouble codes:
ODX name: EV_BCMMQB
ODX version: 017001
Subsystems:
Long coding: 0E4DDD
Long coding: 00A8DD
Trouble codes:
ODX version: 002005
Trouble codes:
15 Airbag
ODX version: 002138
Trouble codes:
ODX version: 020002
Long coding: 0C10
Trouble codes:
17 Dash Board
ODX version: 009052
Trouble codes:
19 Gateway
ODX version: 013020
Subsystems:
Trouble codes:
23 Brake Boost
ODX version: 004001
Trouble codes:
Intermittent
ODX version: 006003
Subsystems:
Long coding: 0D0000
Trouble codes:
ODX version: 013144
Long coding: D102
Trouble codes:
ODX version: 001010
Trouble codes:
Trouble codes:
ODX version: 006003
Trouble codes:
ODX version: 001001
Trouble codes:
Serial number: 0
ODX version: 003042
Trouble codes:
ODX version: 009031
Trouble codes:
ODX version: 001003
Trouble codes:
ODX version: 001001
Trouble codes:
ODX version: 003004
Trouble codes:
ODX version: 003009
Trouble codes:
ODX version: 001003
Trouble codes:
ODX version: 001003
Trouble codes:
