Hi
We have just had PV panels installed and they generate roughly 3Kw on a sunny day, hopefully this will increase once the optimisers are installed.
I also currently have a Hypervolt that charges the car when solar PV export goes over 1.4Kw.
However I would like to install an iBoost, or use the current immersion element with an eddi or similar to use the exported energy between 0 and 1.4Kw, Currently this is lost as exported energy.
I have been looking at the Eddi but I can't seem to tell if you can program it to take the load between 0 and 1.4Kw export and turn off when export would be in excess of 1.4Kwh. Is there any method to achieving this?
In summary I am looking for something that would identify when the export is between 0 and 1.4Kw and shunt it to the immersion heater/ iBoost, and when export would be over 1.4Kw shunt the excess to the car.
