A local outfit that will install a charge point for me have narrowed their install options down to either the Project EV or Zappi. As far as I can tell the Project EV is a rebadged Chinese brand with a poor app that offers no meaningful integration with anything.... Can anyone tell me otherwise?
It's a bit frustrating because the Zappi is expensive, and really seems to be best for users with Solar. I've considered a command socket and Ohme cable, but these folk won't install that for me
however I can't even get anyone else to return my calls, let alone come and take a look at the slightly challenging install. Electrician seems to be the business to be in right now.
Hi I have charged on street in my Cul-de-sac for the past 15 months daily.
I tested the waters with a BMW plug in and I was able to charge so consistently I changed to a leaf about 9 weeks ago.
My point being, no one would have installed me a charge point because I technically don’t have anywhere to charge! 🤣
So my only option was to install a 32A Ceeform (commando) on the front of my property and see how it went.
All you really need is to run a 6mm armoured cable from your distribution board and install a 40A RCBO (assuming you have a modern distribution board) and put a 32A connector on the other end.
Any sparky will do this for you, they done even need to know you intend to use it to charge a car really, it’s just having a 32A outlet installed as far as they are concerned, you could just as easily be plugging a hot tub into it as a car it matters not.
You can then take your pick of whatever portable charger you want to use to charge your car.
Don’t get too hung up on whether the charger has an app.
Any decent EV has an app nowadays that will allow you to monitor the charge progress, set a delay timer on when you want the charge time to start / end and departure time to climatise in time mornings.
