21 - 29 of 29 Posts
We're in Worcestershire. It's about a days work - dash out.
Sent from my SM-N9005 using Tapatalk
Got a text from my wife after she got to work complaining that our 2011 Leaf was blowing cold air, but interestingly the fan setting did not seem to do anything either...it was a constant weak trickle of air. Presumably this is the infamous PTC heater. Will take a look when she gets home, but a wife and cold toes is a bad combination for marital bliss. I am more worried about the misting up of windows from a safety perspective.
MOT booked for Thursday as well.
@Mike Schooling I might be popping up to visit you again (thanks for the windscreen washer pump previously)!
Reactions: Mike Schooling
My Leaf 2012 no heater, leaf spy pro code error B2794 0008 HVAC Heater Pump HAC-114, how is? Thank you
I thought it was safe to purchase a Sunderland built 'Gen 2' 2013+ Leaf as these had the later heat pump.
Am I reading this correctly, that basically all 24/30kwh Leaf's have some kind of PTC heater combined with the heat pump, but still suffer with these common(ish) failures like the original Japanese models?
Acenta and Tekna models have the heat pump as well as the PTC. Visia only has PTC.
leaf spy pro code error B2794 0008 HVAC Heater Pump HAC-114, replace water pump, very nice, air conditioner normal function, thank you
21 - 29 of 29 Posts
