Great YouTube video showing the impact on range of adding 400kg of weight to a Kia Soul EV.
It might be just that the white ones are very efficient ;-)
I had assumed that moving 400kg around several miles would consume energy and therefore impact the range...Weight should have an impact on consumption! That video still doesn't make sense!🤯
May it do while towing since the centre of gravity gets altered significantly?Weight should have an impact on consumption! That video still doesn't make sense!🤯
Don't forget the effect of regeneration which will also increase with load.Center of gravity (the point at which gravity exerts its effect on the car) governs stability, but has nothing to do with economy.
Newton's Law: Force = Mass x Acceleration tells us that, when you accelerate a body, the force required (and therefore the energy consumed) is proportional to the mass of the body. However, if you accelerate once to reach cruising speed, and then perform the journey at constant speed, most of the energy will be consumed, as has been pointed out, in overcoming friction and air resistance, so the effect of acceleration will be small and lost in the noise.
Change the scenario to a van doing local deliveries in city traffic (so lots of acceleration and deceleration) and you will see a pronounced dependence on load.
Do you mind trying to find this discussion?He is not the first to discover this phenomenon.
A few years ago, probably on this forum, I read an account of a conversation a journalist had with the technical development people at Nissan. The journalist asked what range the ENV 200 van could achieve fully loaded and why this was not included in the publicity about the vehicle. The reply was that they had done a full range of tests on the van fully loaded and found no reduction in range compared with the unloaded figures. They then decided that no-one would believe them so just omitted the information from the vehicle specifications.
I wouldn't mind accepting that bet. Taking into account TomH's point that EVs give you back some of your acceleration energy when regenerative braking is employed, I would put money on less effect of mass on efficiency.Probably not a surprise but I bet ice cars are more sensitive to weight and would see a greater effect on efficiency.
