1 - 6 of 6 Posts
hi All,
I am looking to buy a second hand Renault Zoe (2015-2016) and went to see a dealer today. When speaking to the dealer, he said that the car is not able to do quick charging. If I for ex are on the motorway and run out of battery, i cannot go in a service stop and have a coffee while waiting for my car to charge - it would charge at the same speed as it would if i charge it back home, about 10-12 hours for a full charge.
Is that right? Can I purchase an adaptor or different cable to be able to fast charge it?
Tyia!
There are two maximum charge rates on the Zoe 22kW and 43kW, they will both charge at 7kW on a home charge point as home charge points are generally 7.2kW.
The Q model can charge up to 43kW and the R model can charge at a maximum of 22kW.
Speak, Eevee!
No the non-rapid version will still charge up to 3x as fast as at home on a rapid charger. Home chargers are 7kW, but the Zoe will do 22kW on a triple phase charger
I'm biased as I got the non rapid charging version but by my understanding there's not enough of a difference between charging times of the 22kW and 43kW (rapid) versions to really worry about it unless you're up and down the motorway a lot. It doesn't do a full 43 all the time but is more consistent at 22, so you're only looking at something like 30 minutes vs. 40 minutes on a typical 20-80% charge
1 - 6 of 6 Posts
