1 - 6 of 6 Posts
My EO mini pro randomly sent a notification that it started charging and then Stopped charging 8min later using .5kw .
1.5 hours later I get a notification that it has gone offline.
Any ideas?
I have a camera so can see no one has used it.
Regards
Any ideas?
Regards
What router are you using? My EO mini pro has just gone offline and i haven't touched the thing yet. I had to reset at the rcb to get it back to standby but it went offline again earlier this evening.
My guess is that the juice net server had an issue or the router dropped for a few minutes. This hasn't happened again.
My EO Mini Pro was charging last night. It stopped at around 11:30pm and then restarted about 20 minutes later without me initiating it. Does the time coincide with your issue? I’ve not encountered it before
I've had the occasional drop, usually related to the server end. One thing I had to do early doors was ensure my WiFi was using Channel 1 on 2.4Ghz, I had been using Channel 13 and is was super flakey for the EO.
Sent from my Pixel 4 using Tapatalk
My issues were around 4 months ago, since then I haven't had the unit go offline.
However, did it go offline or just stop charging and then start again. If it goes offline, you should get a notification on the app or email.
On my outlander, it charges to around 80% then trickle charges and stops before it reaches 100%. At some random point, it will start charging again and pushes the charge closer to 100%. So, the battery might be self managing.
1 - 6 of 6 Posts
